shocks
Old Jul 31, 2020 | 01:26 PM
clutch1's Avatar
clutch1
Default shocks
For my 1999, FRC, WOULD COIL OVER shocks make the ride....... hard, or too stiff??
Old Jul 31, 2020 | 02:51 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
I certainly would not recommend coil overs unless you are planning to track the car or add REALLY big power. coil overs will definitely have a negative impact on the ride quality of your car. Plus, there's really no need for coil overs on a stock or near stock car. If you're looking to improve the handling of your car without making the ride too "hard, or too stiff" I would suggest swapping your stock shocks out for C6 Z06 shocks and Z51 sway bars. That should help a lot without making it uncomfortable to drive down a city street.
Old Jul 31, 2020 | 03:10 PM
knewblewkorvette's Avatar
knewblewkorvette
I did this on my 02 and it was an improvement.
Old Jul 31, 2020 | 04:27 PM
clutch1's Avatar
clutch1
Do you track your car any, or just a driver?
Old Jul 31, 2020 | 04:43 PM
USAZR1's Avatar
USAZR1
Why start a duplicate thread?
Old Jul 31, 2020 | 05:03 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
Maybe hopeing for a defferent answer.
Old Jul 31, 2020 | 05:08 PM
MWWarlord's Avatar
MWWarlord
I personally have not tracked my car, but I am supercharged with 500 RWHP. My car is set up as a grand touring canyon carver. The stock suspension was definitely NOT good enough after I added the supercharger. I'm currently running the C6 Z06 shocks and Z51 sway bars as I have recommended to you. They work great with the "spirited" street driving that I do (feels like the car is on rails). I care about the ride quality of my car which is why I went with this setup. You can also get stiffer leaf springs if you want it to be even stiffer (but still less stiff than coil overs). If you have real plans to build a track monster with over 550 RWHP, then you may want to look at coil overs. However, on a stock or lightly modified car the only difference between the setup I have recommended and coil overs, is the coil overs will result in a rough ride. If you do have a desire to track your car...great. Be aware that regular track use gets expensive even if you're bone stock as it will require regular tire and brake pad replacement in addition to track fees. I've been told to budget about $1000.00 per track day (although I've not done it myself). If you tell us exactly what you're looking to do with your car, we can give you more specific advice.
Old Jul 31, 2020 | 05:13 PM
MWWarlord's Avatar
MWWarlord
Also, I know you mentioned that you need new shocks, so it would be a good time to upgrade. However, I think it's worth mentioning that it doesn't really matter much what improvements you make to your suspension if you don't have a good set of performance tires. Just something else to consider.
Old Jul 31, 2020 | 06:15 PM
StickTail's Avatar
StickTail
Stock suspension sucks, the car wallows. Z06, FE4 is where it should have be stock, but then the plush ride (automatic trans, 75%) drivers would revolt.
Get a set of new set of Z06 shocks and a set of Z06 springs/sways. They were engineered together so matching them up provides gains.
Old Aug 1, 2020 | 01:20 AM
Hitman227's Avatar
Hitman227
Any Dampening increase over Stock Shocks will be an improvement, but you have to go big (Like Koni's or [Revalved] Bilsteins) to get the most handling benefit. Much cheaper and IMO better overall handling. You don't even have to upgrade springs - stock leaf spring's spring-rate will work great with upgraded shocks, or, can step up to Hyperco AX springs in a lightweight composite leaf spring(s). Reaches the competitiveness of Coil-Overs, without breaking the bank, and only sacrificing ride quality based on a stiffer spring, not a hard shock, for a very great performance configuration.
Old Aug 1, 2020 | 01:43 AM
c4gone's Avatar
c4gone
Do c6z shocks bolt right up without any mods?
Old Aug 1, 2020 | 02:14 AM
strand rider's Avatar
strand rider
With coil overs, you loose the locating action of the lief springs, so you aso have to beef up other stuff to compensate for that loss of locating action, if you want to do it correctly. I was looking into coilovers as a way to keep my lowered ride hight ,in a more mechanically correct way than just adjusting the bolts on the springs..
Old Aug 1, 2020 | 02:48 AM
Hitman227's Avatar
Hitman227
Yes, you are correct in the differences in the way to set Ride Height, but corner balancing can be achieved without Coilovers, this is the most important value in performance handling.
Old Aug 1, 2020 | 08:09 AM
Toys4Life C5's Avatar
Toys4Life C5
St. Jude Donor '21
Originally Posted by c4gone
do c6z shocks bolt right up without any mods?
yes. Easy mod that is a pretty good value in the Corvette world. Firms up the ride quite a bit!
Old Aug 1, 2020 | 11:34 AM
MWWarlord's Avatar
MWWarlord
Great video as always T4L
Old Aug 1, 2020 | 12:04 PM
c4gone's Avatar
c4gone
https://youtu.be/Wfuy0pvZg-g
Great video!
To shocks
