Do these work
Old Aug 20, 2020 | 09:24 AM
Billy Parks's Avatar
Billy Parks
5th Gear
Default Do these work
I have an 02 base coupe auto with 2:73 rear. Terrible low end response. Has anyone tried this? Do they work. This is the only one Ive seen that works on a c5.
JMS PedalMAX Throttle Delay Eliminator [1997-2004 Chevy Corvette C5]
Part Number: 227-PX9704GMC
Old Aug 20, 2020 | 09:43 AM
dmsog's Avatar
dmsog
I seriously doubt that a plug-in device will overcome a high gear ratio. At almost 300.00 for this thing you're a third (or less) on the way to a set of 3:15 or 3:42 gears that will give you what you want if you can install it yourself.
Old Aug 20, 2020 | 10:29 AM
MadMax96's Avatar
MadMax96
I just had my 2.73 gears replaced with a 3.42 unit I found here used. This along with a tune that the shop did and the car is like I envisioned it should be.
If you want to make your car feel quicker - your FIRST mod should be gears. Go with at least 3.42 (there are many threads on this) if you're going to bother. Unless you're taking it to the drag strip, I don't think you'll need a different torque converter although many people seem to swear by them.
Mine still drives smoothly but when you want the power it's there. I'm super happy with the results.
Old Aug 20, 2020 | 11:07 AM
Billy Parks
5th Gear
I believe you are correct. Im going to start shopping. Thank you
Old Aug 20, 2020 | 03:44 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
The truth.. Power costs money. And I am not talking
$300.
Good luck
Old Aug 20, 2020 | 04:47 PM
friou's Avatar
friou
Gears and tune will wake that C5 up!!!
To Do these work
