Cluster rebuild?
Old Sep 17, 2020 | 07:11 AM
Bennett06's Avatar
Bennett06
7th Gear
Default Cluster rebuild?
anyone able to rebuild cluster? Gauges work fine just switches from mph to kmh unhooked switches sti does it
Old Sep 17, 2020 | 12:15 PM
knewblewkorvette's Avatar
knewblewkorvette
I'm not sure it can be rebuilt?
But, you can easily get a used one from some place like Vettenuts
https://vettenuts.net/
Old Sep 17, 2020 | 03:21 PM
jcgunn's Avatar
jcgunn
The PCBs in the C5 are right out of 1970s High School electronics class. As they get old, solder joints can come loose. [see HVAC control dim fix thread] If you have some basic skills with a soldering iron you may be able to fix the unit yourself. Use a magnifying glass to look for bad solder joints. I'd concentrate on the area around the E/M switch. Good luck and let us know.
To Cluster rebuild?
