I am thinking about trying the Hawk Talon rotors with 5.0 pads. Does anyone have any experience with these? Trying to not spend the Baer Eradispeed cost, but it’s an option. Car/goals below:
2002 Z06
800rwhp
Street Driven Only, No Track
Goals: Improved braking over stock rotors/pads without going to a full big brake system.
Car is not driven hard, but car has a lot of power and needs to stop from high speeds on occasion.
Any properly bedded slotted iron rotor will give the desired effect. AC Delco stock zo6 pads if you don't mind dust otherwise any quality ceramic street pad would work too.
2002 Z06
800rwhp
Honestly, with 800RWHP, you really should just go with a big brake setup. The big brakes are a bit expensive, but to get to that kind of power on a C5, you've clearly put way more money than that in it already. Especially on a high HP car, brakes are NOT the thing to cheap out on.
yeah it's funny how people forget and or just wanna cheap out on the brakes.
May I suggest Carbotech AX6 pads along with Centric premium plain face rotors this will take care of your street needs,
The AX6™ is specifically engineered for Autocross applications. A high torque brake compound delivering reliable and consistent performance over a very wide operating temperature range of 50°F to 1000°F + (10°C to 537°C+). The advanced compound matrix provides an excellent initial bite, high coefficient of friction at lower temperatures along with very progressive brake modulation and release characteristics. Many drivers use the AX6™ for street driving as well, even though Carbotech™ doesn’t recommend street driving with AX6™ due to possible elevated levels of dust and noise. AX6™ is NOT recommended as a race compound in most applications.
If you are just stopping once from 120, stock brakes are more than fine. If you want to road race on a private course, repeated stops and starts over and over require big brakes to shed the heat. For what most of us do - C5 brakes are plenty good.
