LS7 conversion
Old Sep 29, 2020 | 11:43 PM
CASEWORER's Avatar
CASEWORER
Default LS7 conversion
I have a LS7 in my c5 Z06 my question to those of you that have this same set up how many of you are useing A MSD intake? I know the firewall has to be cut to do this but did you also have to change and use shorter motor mounts. I have read some posts that said it just won't fit. I need to hear from someone that is actually using a LS 7 block that has done this. Thanks guys.
Old Sep 30, 2020 | 02:58 AM
speedmon's Avatar
speedmon
Yes.
Not really a cut firewall...I would call it more of a notch.
And I have shorter (lowered) solid mounts......so it fits under the stock hood as well.
Its the best upgrade for a C5......faster than a C6Z06.
Old Sep 30, 2020 | 08:19 AM
dskinsler83's Avatar
dskinsler83
Didnt know the LS7 block was any different.
To LS7 conversion
