C5 of the Year - Modified
Received 1,333 Likes
CI 2-3-4-5-6-7-8-9-10-11-12
Wounded Warrior Escort '11
St. Jude Donor '03 thru '24
NCM Lifetime Member
For Corvetteforum’s 2020 C5 Corvette of the Year competition you have two choices for entering your Corvette – Unmodified and Modified.
For the Unmodified category, minor modifications are permissible; for the Modified category, your modifications can be for appearance or performance or both.
This thread is for entering your Corvette in the Modified category.
You can enter just one of the categories of competition and you do so by posting one photo of your C5 in the appropriate thread no later than 11:59 p.m. PDT, Oct 14. Moderators then will pick ten of their favorites as finalists and set up a poll to allow you to vote on which of those finalists is the C5 Corvette of the Year in each of the above-referenced categories. The judging, of course, is subjective and will be heavily influenced by the quality of the photographs submitted for the entries.
The contest is open to site users across the globe.
The reward in each of the categories is bragging rights and a designation under your user ID declaring your winning status.
In subsequent months, we’ll feature other generations for Corvette of the Year with the winner in each of those generations competing for Corvetteforum Corvette of the Year. The Corvetteforum Corvette of the Year will be featured on the mobile home page of the site.
The fine print: One entry per member. This contest is open to site users over the age of 18 who own the car they enter. Entry photos must have been shot by the Corvette's owner. That is to avoid professionally made photos which might give the entrant an unfair advantage. If you want to enter a photo of you in or by your car, that's fine so long as the picture was not taken by a professional photographer.
Jason Blue Boost (10-11-2020)
Popular Reply
10-01-2020, 11:42 AM
NCM Lifetime Member
Received 3,973 Likes
St. Jude Donor '18-'19-'20-'21-'22-'23-'24
Corvette Forum C5 of the Year Contest- Modified
Larry Lewis - 2003 Torch Red Z06 664 RWHP/614 RWTQ
Engine components:
GM LS2 6.0L Aluminum LME 402” Stroker Forced Induction Short block, LME Billet 24X Reluctor Wheel, Callies Compstar Crankshaft w/ LME Blueprinting Process, Callies Compstar H-Beam Connecting Rodsw/ARP 2000 7/16" Bolts, Wiseco Forged FI Gas Port Pistons, Wiseco .200” Wall Heavy Duty Steel Wrist Pins, NPR Ring Pack, Stainless Top (for high heat applications) Napier Second, 3mm Oil, Clevite H Series Mains & Rods Bearings w/ARP Main Studs, Bore: 4.005”, Stroke: 4.000”, Rod Length: 6.125”, Compression Ratio: 9.5:1, AFR CNC 210cc LSX Mongoose Cylinder Heads w/ARP Head Studs, LG Motorsports G5X3 112 LSA Cam, Vengeance Racing .660 Lift Dual Valve Spring Kit w/Ti Retainers, Comp 850-16 Hi Performance Hydraulic Roller Lifters - GM Lifter Trays, Comp Push Rods & Trunion Kit, Melling Hi Volume Oil Pump for LS, Katech Timing Chain, Intake: FAST 92 w/GM LS2 TB (TB Polished by CBM Motorsports), ATI Super Damper Harmonic Balancer for LS Wet Sump, FAST LSXR Billet fuel rails/Ano Tuff-AN fittings/Braided-AN line, 60# Siemens Injectors, A&A V3 Si Trim Supercharger System for C5 Z06 (Polished) w/3.6 pulley, GM 3.3 Bar MAP Sensor-Gen IV, Dewitt High Performance Radiator w/SPAL Dual Fan Kit, Hypertech 160 Degree Thermostat, Vengeance Racing Custom Valve Covers w/Coil Relocation Kit, Vengeance Racing High Temp Spark Plug Wire Insulators, NGK TR6 Spark Plugs (gapped .035), Moroso Oil Catch Can, Mechman C5 170a Polished Alternator
Exhaust:
ARH 1 7/8” Ceramic Coated Headers, w/3” catted X-pipe and Mid-section, DMH Performance electric exhaust cutouts, Borla ATAK axle back
Drive train, Suspension, & Brakes:
Monster LT1-S Twin Disc Clutch (w/speed bleeder), RPM 3” aluminum driveshaft with rebuilt torque tube, Elite Engineering 1/4" Aluminum ceramic coated tunnel plate with thermal-abs, RPM Level V T56 Trans (with Anti-venom Mod), RPM Stage III Differential, DTE/Hoosier C5 Diff/Trans Strut Brace, Pfadt Racing Trans Mount, LG Drop Spindles, Swaybars, and GT2 Adjustable Coilovers, Powerstop Ceramic Brake pads with Slotted and Drilled Zinc Coated Rotors, Russell Stainless Steel brake lines with Speed Bleeder bleeding valves
Exterior:
MCM Standard Hood w/Exposed Carbon Fiber, Radioflyer Innovations Luminator Low Rise Headlights, Modified Halo LED Tail Lights, C5 Hyperflash and Hi-4 harnesses, Clear & Black Front Corner Housings with Cree Amber LED marker and turn signal bulbs, C5 Complete Exterior LED Conversion package, Vette-Lights C5 Laser LED rear marker lights, TPE T2 Wide body Rear quarters, Corvette Creationz Urethane Duckbill Rear Fascia, ACI Front Spoiler and Side Skirts, Apsis Black Carbon Fiber C5 Z06 Rear Brake Duct Inlets, CCW SP510’s 19x10 &19x13 with 275/35/19 & 345/30/19 Nitto Invo’s
Interior:
Apsis C5 Super Deluxe Seats with black carbon fiber side and back panels (perforated torch red/solid ebony nappa leather w/torch red stitching), Apsis C5 Dash (solid ebony nappa leather w/torch red stitching), Apsis C5 Passenger Airbag cover (solid ebony nappa leather w/torch red CORVETTE embroidered), Apsis C5 door panels (solid torch red/ebony nappa leather w/torch red stitching), Redline Goods console armrest cover, shifter & e-brake boot, Apsis D type sport steering wheel (black carbon fiber and perforated torch red nappa leather), Apsis C5 Airbag Cover w/split Red Cross Flag logo (perforated ebony nappa , solid ebony nappa w/torch red stitching), Apsis Black Carbon Fiber single din radio bezel, center console base, traction control panel, interior temp sensor cover, e-brake handle, door latch bezels, door pull handles, and HUD bezel, Safety Restore re-webbed Red C5 Z06 seatbelts, Kenwood KDC-X500 1 din CD-Reciever w/PAC ROEM-Vet1 Interface, Pioneer 800 watt Mono Subwoofer Amp, JL Audio Power Wedge™ sealed enclosure with two 12" TW1 subwoofers, Aeroforce Interceptor dual scan gauges/Autometer dual A-pillar gauge pod, Radioflyer Innovations C5 Complete Interior LED Conversion package, TMOD 20% reduction shifter w/delrin **** and modified lower shifter box, Elite Engineering C5/Z06 Standard Gas and Dead Pedal Set, Weathertech Black Floorliners for driving / Black Lloyd’s floor mats w/torch red C5 cross flag and Corvette Racing logos for show, Vettenuts pre-cut C5 interior insulation kit, C5 Corvette Z06 Quiet Ride Compartment Divider, Car Motorsports 3 piece trunk lid panels with torch red C5 cross flag logo
"A hot rod is never finished" Billy Gibbons - ZZ Top
NCM Lifetime Member
Engine components:
Exhaust:
Exterior:
Interior:
The following 17 users liked this post by lewislgZ06:
BT1991 (10-05-2020),
C5R USA (10-07-2020),
CamarosRus (10-06-2020),
Cherrywine362 (10-12-2020),
doublenut9 (10-10-2020),
and 12 others liked this post.
The following 11 users liked this post by Jason Blue Boost:
IowaZR1 (10-07-2020),
lewislgZ06 (10-08-2020),
mstromquist (10-02-2020),
and 6 others liked this post.
The following 9 users liked this post by DECON BLUE:
Malekith (10-18-2020),
MWWarlord (10-07-2020),
and 4 others liked this post.
Received 3,916 Likes
2015 C5 of the Year Winner
So why is nobody postin' up in this great thread? We need more custom Vettes in here. Come on people....
The following 8 users liked this post by BT1991:
mstromquist (10-06-2020),
partspusher (10-06-2020),
and 3 others liked this post.
The following 13 users liked this post by Fastbird:
and 8 others liked this post.
The following 17 users liked this post by Johnson 92:
Dashracing (10-10-2020),
FourG63 97GST (10-05-2020),
Received 1,899 Likes
Uh,oh! Looks like my dog needs to stay on the porch.
The following 11 users liked this post by IowaZR1:
lewislgZ06 (10-07-2020),
The following 13 users liked this post by jd_black_00:
C5R USA (10-09-2020),
jbbowtie (10-15-2020),
Johnson 92 (10-05-2020),
The following 16 users liked this post by FourG63 97GST:
jd_black_00 (10-06-2020),
and 11 others liked this post.
The following 8 users liked this post by Keev1414:
mstromquist (10-07-2020),
The following 14 users liked this post by charger21:
Johnson 92 (10-06-2020),
and 9 others liked this post.
The following 15 users liked this post by USAZR1:
BT1991 (10-07-2020),
Fastbird (10-06-2020),
and 10 others liked this post.
The following 4 users liked this post by partspusher:
The following 10 users liked this post by PerryKing:
and 5 others liked this post.
The following 6 users liked this post by Z06-Dreamin:
mstromquist (10-08-2020),
Route99 (10-12-2020),
and 1 others liked this post.
Received 3,112 Likes
St. Jude Donor '21-'22
2004 Corvette Convertible
Mods: A&A Supercharger kit, Stage 5 transmission from RPM, Z06 Titanium exhaust, C6 Z06 Shocks, C6 Z51 sway bars, PowerStop Z23 rotors, Z06 rear brake cooling intakes and ductwork, Bi-Xenon ACA headlights, Halo LED tail lights, LED reverse lights, Laser LED rear side marker lights, and various cosmetic upgrades.
The following 7 users liked this post by MWWarlord:
and 2 others liked this post.
2023 C5 of the Year Winner - Modified
2023 Corvette of the Year Finalist (C8) - Modified
2023 Corvette of the Year Finalist (C6) - Modified
2022 C8 of the Year Winner - Modified
2022 C6 of the Year Winner - Modified
The following 11 users liked this post by DNAST1:
C5R USA (10-08-2020),
Johnson 92 (10-07-2020),
MosEspa (10-08-2020),
mstromquist (10-10-2020),
