c5 Active Handling
Old Oct 4, 2020 | 07:52 PM
lukelussier87's Avatar
lukelussier87
3rd Gear
Default c5 Active Handling
Hello! i recently purchased a nassau blue c5 corvette. Sometimes when it the brakes an alert comes up as Active Handling and the car seems to slide forward a bit. Its hard to describe. Has this ever happened to anyone on here? Any help would be appreciated. Thanks.
Old Oct 5, 2020 | 03:35 AM
Jistari's Avatar
Jistari
Theres braking....and then theres braking. If you mean hard braking (maybe on a turn) you may see active handling come on as the system tries to correct yaw induced by sliding, but in reasonable straight line braking all you should get is anti-lock braking....which I am not sure shows on the display.
Old Oct 5, 2020 | 08:56 AM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
ABS will show on the display and note "ABS ACTIVE"
What kind of braking are we talking here?
Old Oct 5, 2020 | 09:20 AM
I never had active handling pop up on the DIC when braking that I can recall. Not saying it couldn’t happen, just I never experienced it.
Old Oct 5, 2020 | 09:49 AM
jjc508520's Avatar
jjc508520
The car looks nice - howsa about a few more pics?
Old Oct 5, 2020 | 09:58 AM
lukelussier87
3rd Gear
It is when i am in a straight line. Come to think of it it happens mostly after i make a hard acceleration and go to hit the brakes.
Old Oct 5, 2020 | 09:59 AM
lukelussier87
3rd Gear
straight line medium braking. normally after an acceleration
Old Oct 5, 2020 | 10:11 AM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
Welcome to the forum, and congrats on the car. Yeah, it sounds like the car is reacting to your "spirited" driving. As long as it doesn't happen during "normal" driving, I wouldn't worry too much about it.
Don't forget to SAVE THE WAVE
Old Oct 6, 2020 | 04:30 AM
Jistari's Avatar
Jistari
Stock wheel/tire sizes? If they arent that may do it..... other than that, no it shouldnt be showing.
You have any codes showing in the self diagnostic?
Old Oct 6, 2020 | 10:08 AM
friou's Avatar
friou
I haven't seen that message on my '99, but I don't push my car very hard these days.
Old Oct 8, 2020 | 02:02 PM
UM Rebel's Avatar
UM Rebel
It is likely that your Steering ?Wheel Position Sensor is failing. This can send a bad signal to active handling system and cause unexpected brakeing and power loss.
It can also cause cruse control to randomly disengage. if your car is 2000 or later new sensor is about $70. Changing it is a real PITA. The good news is you can disable active handling by pressing the button on your console.
Welcome to the forum!
To c5 Active Handling
