Hub Stands
Old Oct 16, 2020 | 07:36 PM
I’m Z one's Avatar
I’m Z one
2022 Corvette of the Year Finalist -- Modified
2021 C5 of the Year Winner - Modified
Default Hub Stands
I have not seen anything on the forum regarding hub stands so I thought I’d share some pics. I picked up a set, installed them in preparation for the upcoming winter storage. The car is supported by the stands and it keeps a load on the suspension. I put my rims and tires in the basement and keep them out of the cold which is never good for any performance tire.
Old Oct 16, 2020 | 08:49 PM
dbgoodwin's Avatar
dbgoodwin
I don’t know why, but that really freaks me out.
glad I live in a place that I can enjoy my car year round at least! Yours does look mighty clean though
Old Oct 16, 2020 | 09:01 PM
Old School's Avatar
Old School
Admit it, you just wanted to show off your fancy brakes
Old Oct 16, 2020 | 09:57 PM
flyingmfrc's Avatar
flyingmfrc
2020 C5 of the Year Winner- Unmodified
Do they make those adjustable?....looks better than jack stands.
Old Oct 17, 2020 | 07:38 AM
Adwest52's Avatar
Adwest52
2021 C5 of the Year Finalist - Unmodified
Looks good but seems like more work than what it's worth.
Old Oct 17, 2020 | 08:31 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Those are really cool, and I can appreciate their function, and I can understand your desire to keep your tires out of a cold garage. HOWEVER................
There's always the possibility, no matter how slight, that in an emergency, you'd want to get the car out of the garage...NOW. With your car supported by those stands, you can't. I can see, though, how they could be helpful when you're doing some sort of quick maintenance job.
This brings up the question of what I do, during the winter, to preserve my tires from the cold. I'm the original owner of my C-5, and when the car was about 2 years old, I unfortunately ran over a piece of debris that put a severe cut in the LR tire, right where the sidewall and tread met. The tire still held air, but damage at that point on a tire, makes it unusable. I replaced the one tire, but over time, the OE tires wore at a quicker rate, with the RR wearing more quickly than the LR, and the difference in OD became more pronounced, and the limited slip clutch pack was VERY unhappy.
Since I was thinking of a set of custom wheels, anyway, I bought 4 wheels and 4 tires at that time. I kept the OE wheels, with those tires on them, and use them to store the car on, during the winter.
Old Oct 17, 2020 | 08:46 AM
I’m Z one's Avatar
I’m Z one
I wish I could put on any C5/C6 rim & tire set but the issue I have is that I would need 18/19 rims to clear my brakes and they would cost more than the Hub Stands did (even used rims & tires). Plus, I'd have to store them when not being used.
Old Oct 17, 2020 | 08:49 AM
I’m Z one's Avatar
I’m Z one
No sir non adjustable. And I suppose they could be used for the same purpose as jack stands.
Old Oct 17, 2020 | 11:00 AM
knewblewkorvette's Avatar
knewblewkorvette
Never even heard of such a thing. Pretty neat but they are not cheap, at least the ones I saw looking them up.
It's new to me that one should not let summer tires get cold. All I ever heard was just not to drive with summer tires in the winter. Lucky for me, the garage where I keep my C5s is heated. I set the heaters to 45 degrees but not for the tires, but for everything else I have stored out there (like paint, etc)
Old Oct 17, 2020 | 12:29 PM
leadfoot4's Avatar
leadfoot4
In my case, I think it would be a combination of the cold, as well as the weight of the car sitting on the tires, in the same position for 4 months, that could cause issues. Since I have an alternative course of action, and C-5 tires aren't all that cheap, it's what I do. My wife also has a "summer driver", but since I don't have any "spare" wheels an tires for it, all I can do is inflate the tires to 42 PSI, and put some carpet squares under the tires. One other thing, my garage, although attached to the house, is unheated. It's not uncommon for the temps in it to get down to 0*F or even lower.....
Old Oct 17, 2020 | 12:30 PM
leadfoot4's Avatar
leadfoot4
Understand...................
Old Oct 17, 2020 | 07:06 PM
I’m Z one's Avatar
I’m Z one
Same here attached garages aren’t that warm unless they are heated. My garage is fully dry walled three of the four walls are insulated meaning the garage doors insulated and it’s probably 10° warmer inside the garage and it is on the outside.
Old Oct 17, 2020 | 07:40 PM
Sean_emory's Avatar
Sean_emory
The entire weight of the car is supported on the studs for the wheels?
Old Oct 17, 2020 | 09:02 PM
dbgoodwin's Avatar
dbgoodwin
Out of curiosity, what do you think the wheels and tires, which support the entire weight of the car, are attached to?
Old Oct 17, 2020 | 09:41 PM
walleyejack's Avatar
walleyejack
am just wondering... does the corvette factory take all the tires off the cars when they are built in the winter and store them inside until the cars are ready to transport ?
Old Oct 17, 2020 | 11:05 PM
lewislgZ06's Avatar
lewislgZ06
NCM Lifetime Member
St. Jude Donor '18 thru '26
Corvette wheels are hub centric. The weight is on the hub lip, not the lug studs.
Old Oct 17, 2020 | 11:47 PM
FX VETTE's Avatar
FX VETTE
I think those fricken things are cool in YOUR situation.
To Hub Stands
Old Oct 18, 2020 | 12:45 AM
jdmvette's Avatar
jdmvette
Night Owl for life
a vette with legs
Old Oct 18, 2020 | 10:31 AM
jackthelad's Avatar
jackthelad
Not so sure. They always seem pretty loose to me before the nuts are tightened. To have the hub carry the load, the fit would have to be very tight.
Old Oct 18, 2020 | 10:39 AM
dbgoodwin's Avatar
dbgoodwin
right, as opposed to here where the hub stands are clamped to the... hub.
