Unlocking Without Alarm
Old Oct 25, 2020 | 10:11 PM
VAvette98's Avatar
VAvette98
Default Unlocking Without Alarm
So long story, but my stock 98 key fob will not train on the car. Happened to find another used 98 fob on ebay (same p/n & fcc id) and it wouldn't work either. I have working TPMS so I do not think my receiver needs replaced. I have spent time and all kinds of methods to get either of the fobs to train and they just wont, yes new batteries too. Anyways, I am kinda giving up on the fobs completely. My question is, when I lock the car from the drivers automatic door switch and unlock the drivers door with the key, the alarm goes off. Is there any way around this? I dont mind manually unlocking the door with the key but I would like to be able to lock the car without the alarm going off every time I unlock the door. I guess I could pull the horn fuse, but that's not a long term solution. I know I can stop the alarm by putting the key in the ignition, but I dont want the alarm going off every morning when I leave for work.
Thanks!
Old Oct 25, 2020 | 10:49 PM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
You could upgrade to the 2001-2004 system with the new fobs and receiver and TPMS. That is probably what I would do.
https://www.corvetteforum.com/forums...-and-fobs.html
Old Oct 25, 2020 | 10:54 PM
DWAVette's Avatar
DWAVette
Default 99
I have a 99 with non-functioning fobs also. I have tried thee different fobs, batteries, numerous times at programming, no success.
I just use the key to unlock it on the rare occasion I lock it.
My alarm does not sound when I unlock the car, however.
What happens when you use the key to LOCK the car and then UNLOCK the car?
Old Oct 26, 2020 | 11:47 AM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
I think if you lock the car with the key, you should be able to unlock it without any issues.
Old Oct 26, 2020 | 01:55 PM
bc6152's Avatar
bc6152
This is good advice I have a '98 and this is exactly what I did to upgrade. New 2003 receiver: $35.00 - Contemporarycorvette.com - new TPMS from Amazon were $160.00 but prices vary greatly from others. Two new key fobs from Ebay - $10.00. Wiring in the receiver is very easy as all wires from early cars match with later models. Simply splice them in... GOOD LUCK with whatever you decide.
To Unlocking Without Alarm
