Mesh wind deflector or plexiglass?
Old Nov 10, 2020 | 11:11 PM
JimHarris4's Avatar
JimHarris4
Default Mesh wind deflector or plexiglass?
Any comments on which type of wind deflector? I’ve read plexiglass scratches easily.
Would like to find a used one since I’m not sure they make that much difference?
Thanks for your guidance.
Old Nov 11, 2020 | 05:32 PM
captaineddie's Avatar
captaineddie
I have the Plexiglas and consider it to be worthless. It is pretty at night, though, with the LED option.
Old Nov 11, 2020 | 05:42 PM
o2bnkc's Avatar
o2bnkc
I don't have either one, and that being said, I like the mesh ones for looks.
Old Nov 11, 2020 | 06:49 PM
JimHarris4's Avatar
JimHarris4
Default Alperta wind deflector?
Wow. No help at all? I keep hearing 60-80% reduction. I have some hearing loss and the wind at highway speeds can be loud.
Anybody use the Aperta version ?
Old Nov 11, 2020 | 07:24 PM
captaineddie
Neither my wife nor I can tell any real difference. I had a mesh one on my BMW Z4 and it helped a lot. I don't know how one would work on your Corvette.
Old Nov 11, 2020 | 08:14 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
I have the mesh wind blocker. It does work especially with the windows up on the highway. Definitely lowers the wind buffeting. I would say it's worth it as long as it's not too expensive. I only use mine if I'm on a long highway trip.
Old Nov 12, 2020 | 01:35 PM
Hepcat's Avatar
Hepcat
My 2000 vert had the GM OEM included which is just a black frame and plexi. It's very easy to install and no drilling/mods needed. I believe there's a slight improvement with wind at modest to highway speed but as I'm driving with the top down, not really a major change in my view in ambient noise or air flow.
Old Nov 12, 2020 | 07:18 PM
I would probably go with the mesh one. Perhaps an unfounded concern, but I would be worried the plexiglass one would scratch.
Old Aug 18, 2021 | 12:26 PM
Lenny08's Avatar
Lenny08
I have the OEM mesh one and I do notice a difference. Only downside is that you have to remove it before raising the top. I have read that some people leave them in but previous owner of my car had it installed by dealer and if windscreen is in place top will not move. I assume that there is a switch in the mounting bracket that prevents top from moving when windscreen is in place.
To Mesh wind deflector or plexiglass?
