LMC5 or not?
Old Nov 27, 2020 | 10:11 PM
bc6152's Avatar
bc6152
Default LMC5 or not?
I have a '98 and the column locks each time I remove the key. It also unlocks when I insert the key. No column lock recall was ever performed on my car. After 22 years of this function locking and unlocking correctly, working perfectly, would it be possible that no alteration (LMC5) should be done? I read posts on here where members install it and then have issues after. I don't want to cause an issue that I don't currently have.
I'm aware that most of you highly recommend that the LMC5 should be installed anyway.
Popular Reply
Nov 28, 2020, 09:38 AM
rrwirsi's Avatar
rrwirsi
Originally Posted by bjones7131
I have one in the car but never installed it as of yet. I installed one on my former 01 and don't cherish crawling around in the footwell again. I keep a tender on battery so its always fully charged, rolling the dice at this point. I subscribe to the old saying, if it ain't broke don't fix it but this one is a bit different. I'll eventually get to it.
I also subscribe by the Murphy's Law, “If something can go wrong, it will.” An addition to this law reads, “and usually at the worst time.” You have been warned.
Old Nov 27, 2020 | 11:09 PM
rrwirsi's Avatar
rrwirsi
The only issue I had after the LMC5 install was sometimes the message to pull key wait 10 seconds would appear. That was resolved when I did the 'Brown Wire' optional procedure explained in the kit. The install was simple for both procedures. Like yours, my 04 never had the correction done. But I decided to install the LMC5 anyway so the steering wheel lock issue is no longer a worry.
Old Nov 28, 2020 | 12:48 AM
1999corvettels1's Avatar
1999corvettels1
Well I had the recall done in 2004, by GM, steering wheel still locked after pulling key, then summer 2018 it got me.
Stranded at movie theater in July after watching Jaws, luckily I was able to pull battery and gf gave me ride home, battery was a little weak, charged it went back after about 4 hours, took several tries and finally got it unlocked.
Drove home parked in garage, no more driving until putting that LMC5 on with brown wire mod.
Before that took trip to L.A. area would have been really bad to get stranded far from home.
You should buy the kit, one day it WILL get you, I ignored it for years thinking I was ok.
Old Nov 28, 2020 | 01:18 AM
My advice, install the kit. Seems like a column locking happens at the most inopportune time.
Old Nov 28, 2020 | 08:44 AM
Old School's Avatar
Old School
I installed it on mine even though I wasn't having any problems
Old Nov 28, 2020 | 09:27 AM
bjones7131's Avatar
bjones7131
Old Nov 28, 2020 | 09:38 AM
rrwirsi's Avatar
rrwirsi
Old Nov 28, 2020 | 10:38 AM
djohn3853's Avatar
djohn3853
St. Jude Donor '21
I've only had my c5 for a year and a half. its a 99. I tried to determine if there were any outstanding recalls on it. went to 2 different sites and put in vin. nothing came up. does that mean the lmc5 has been fixed?
in another thread, someone said if you can turn the steering wheel with the car off, then there is no issue. But all these threads about column locking up has me concerned.
Also, i see references to lmc5 kit, but also a bypass kit. are they the same? which is the one to buy if i decide to do it? I see 3 different ones on Amazon alone.
Old Nov 28, 2020 | 11:59 AM
bjones7131's Avatar
bjones7131
Try turning your wheel with car off, if it turns someone took the car in for the recall yrs ago but this was a GM bandaid only and your car is apt to have the column lock and message again especially if you have a weak battery, this triggers the column lock and message condition. There are 2 components to fix the issue that I am aware of, the LMC5 being most popular. Compliance Eng. Out of California designed it and you can get it from them. Google them. Hope this helps.
Old Nov 28, 2020 | 12:24 PM
djohn3853's Avatar
djohn3853
St. Jude Donor '21
So, in other words, my car already has the bypass? is that right? and i would only need the lmc5?
yes, i found Compliance eng and they have an excellent video on youtube for installing it. $40 from them. not bad.
Old Nov 28, 2020 | 12:25 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
The LMC5 is the most common fix these days. I have had the "column lock bypass" installed in my '98 since 2007 without any issues. It's definitely not the same thing but it does work also. I did buy an LMC5 a couple years ago just as a backup in case I need it. You also have to consider that if your car has had the GM recall done on it then they most likely did the 2 mph fuel cutoff at that time also. If they did and you get the message before you install one 9f these fixes then you won't be able to drive the car anywhere until the problem is fixed. I had my cutoff tuned to 200 mph so that won't be an issue anymore either.
Old Nov 28, 2020 | 12:42 PM
bjones7131's Avatar
bjones7131
I never read where you said the wheel turns when car is off. If it does YES it had the recall done from previous owner. Video is very helpful.
Old Nov 28, 2020 | 12:43 PM
Lazarus Long's Avatar
Lazarus Long
I asked my self the same question. I went ahead and installed it, there has been no down side. It is one of those situations where prevention of a problem is far easier than dealing with the problem once it arises. I decided it was better to install it in my own garage when convenient for me than dealing with a locked steering wheel in a parking lot someplace, possibly at night.
Old Nov 28, 2020 | 01:51 PM
wrmiles's Avatar
wrmiles
Either install it or have it in the car ready to go. Prior to getting mine, I had a problem at a rest area on the interstate. Luckily I was able to get it unlocked and going.
Old Nov 28, 2020 | 04:21 PM
friou's Avatar
friou
My '99 never had a problem and then out of the blue it locked up, luckily in my driveway. Going back I thought that if it hadn't happened in the last 17 years it wasn't going to. WRONG!!!! Get the LMC5 and do yourself a huge favor. I go with rrwirsi's post above concerning things going wrong.
Old Nov 28, 2020 | 07:41 PM
dbgoodwin's Avatar
dbgoodwin
I can’t think of any logical reason not to install it.
Old Nov 28, 2020 | 07:47 PM
6spdg37s's Avatar
6spdg37s
do it ! I am doing it on the c5 I just got. Better safe than sorry, its like a 60 dollar insurance policy
To LMC5 or not?
Old Nov 28, 2020 | 09:29 PM
jackthelad's Avatar
jackthelad
The Feb 2006 GM recall (04006C) fixes the problem. I had it done around 2010 and no issues since. Chevy dealer did it for free, no need for an aftermarket fix. Completely diasables the lock mechanism.
Old Nov 30, 2020 | 09:17 AM
Lazarus Long
The recall only disables the lock on C5s with an automatic transmission.
Old Nov 30, 2020 | 09:48 AM
oharal's Avatar
oharal
my 2002 worked fine until it didn't in 2015. Left me stuck at my apartment complex's mailbox. At a minimum, it's worth having on hand for when it does fail. But it will fail at the gas station after you fill up and you'll be asking to borrow a paperclip from a crackhead so you can release the BCM pins and laying over the passenger door sill with your legs out in the road where some idiot in a lifted brodozer he financed at 14% will run over your feet.
