New Wheels
Old Dec 16, 2020 | 10:25 PM
moxieman's Avatar
moxieman
1st Gear
Default New Wheels
Need help. Want to put new wheels on C5. Original rear is 18x9.5 with +65 offset. New wheels are 18x9.5 with +57 offset. Want to keep same size tires of 275/40zr18. Will these work?
Old Dec 16, 2020 | 11:38 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Old Dec 17, 2020 | 07:43 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I would ask a tire store in your area, perhaps ask two stores, and see they tell you the same answer!
Old Dec 17, 2020 | 09:56 AM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
You're talking about a difference of 8mm. That means the new wheel will sit 8mm further outside the rear wheel well from the existing setup.
It will be fine. No need to call anyone.
Old Dec 17, 2020 | 03:34 PM
USAZR1's Avatar
USAZR1
I never understood why GM used two rear wheels of the same width, with the same tire size, but different offsets. Seems a little strange.
Old Dec 17, 2020 | 03:41 PM
djohn3853's Avatar
djohn3853
St. Jude Donor '21
but is it GM doing this, or is it the wheel manufacturers?
Old Dec 17, 2020 | 04:14 PM
USAZR1's Avatar
USAZR1
I'm sure GM specified what they wanted and the manufacturer built them to that spec.
Old Dec 17, 2020 | 06:04 PM
djohn3853's Avatar
djohn3853
St. Jude Donor '21
Maybe that size/offset pattern is stock on another GM vehicle. and it's close enough for c5. Don't know, just guessing.
Old Dec 17, 2020 | 07:34 PM
jamieo's Avatar
jamieo
Originally Posted by Stingroo
You're talking about a difference of 8mm. That means the new wheel will sit 8mm further inside the rear wheel well.
It will actually be 8mm out.
Old Dec 17, 2020 | 07:48 PM
Stingroo's Avatar
Stingroo
You're right. I wasn't paying super close attention this morning. lol
Old Dec 17, 2020 | 07:50 PM
USAZR1's Avatar
USAZR1
No, it's not.
Old Dec 17, 2020 | 07:53 PM
USAZR1's Avatar
USAZR1
If I had to choose between the two offsets, I would choose the +57 on a 9.5" width wheel. If the wheel was 11" wide, my preference would be the +65.
To New Wheels
