Oh well , repairs time.
So, drove back home, about 40 miles and waiting till the next day to put it on the quickjacks and see what all was broke. Did have intentions of repainting the front again next Spring but gonna be sooner now. So took a pic to the damage from the outside before going to work to take the front bummer off.
Wow, Lots tore up after I got the thing all apart.
So today, Cleaned and measured and build a card board template to guide on making a fiberglass piece to attach to the innner fender. Then super glued a few cracked place and holding them closed with welding grip pliers. Plan to just close off the air inlets to the brakes on both sides as I don't ever drive this car hard enuff for the brakes to need cooling. Probably just do a glass patch for the drivers side also. Can't see any of that stuff once the car is back together anyway so does not have to be perfect.
So, tomorrow is , check the glue job and add is necessary, check to see if one of the parts places in town have fiberglass kits, if not order it.
Then, after that's done we'll start checking for the other stuff. Vette Villain's 1st inquiry as I've use them before on parts.
Will; continue on with the job on this thread in the future.
Then after the fiberglass work, will see about getting parts needed on the way. Hoping to find a silver fascia but if not , I'll just paint it to match.
Popular Reply
A trip about town, coffee and conversation at the Fire Station and back home to wash Da Car.
All is good.
And Da Truck gets a break!
If I ever had to do this job again, I would do it a different way for sure but with cold weather and lots of rain, it was get er done and back on the road.
Total cost was right at 859 bucks from start to finish. llllllllllllllllllllllllllllllllllllllll llllllllllllllllllllllllllllllllllllllll llllllllllllllllllllllllllllllllllllllll llllllllllllllllllllllllllllllllllllllll llllllllllllllllllllllllllllllllllllllll llllllllllllllllllllllllllllllllllllllll llllllllllllllllllllllllllllllllllllllll llllllllllllllllllllllllllllllllllllllll llllllllllllllllllllllllllllllllllllllll llllllllllllllllllllllllllllllllllllllll lllllllllllllllll
Building a fiber glass panel to fix in place. Had it layed over a cardboard mock up.
Then took it off the cardboard / plastic bag set up and put another coat of epoxy on it.
Next was kinda clean up where it's gonna fit , pin it in place and add a strip of glass and epoxy to hold it in place. Tomorrow , More glass and epoxy will be added.
Have located the Right Fog light cover and spoiler so will order that tomorrow. Next is finding a 2nd hand nose.
Did finish the inner fender and painted it.
And did get parts in from a salvage group but they sent the rear inter fender piece that covers the computer department instead of the spacer between the front of the inner fender and the spoiler. So , decide to just put some fiberglass on it and drill the hold out.
The before with the corner torn off.
And the after patched and hole drilled.
The one pint paint kit from New Orleans is on the way to me today says an email from the company.
Now, the wait for the nose section to come to a near by Fedex shipping depot and I go pick it up.
Decision a few days ago was not putting the air tubes for the brake cooling back in. As would have to cut the hole and notches for the right side and found a bit of damage to the air tube, decided not to put either one back in. No way I'm ever driving fast enuff or racing where that is really necessary.
So, let's stop up the hole on the left side to keep rain water and stuff being thrown by the tire inside the fender wall.
So, some pieces of fiberglass, a bit of sanding, some epoxy , some paint and VaLaaa. We good.
Heck it's not ever gonna be a show car and with 159K miles on her , she just wants to be on the roads and not some car show or even in town that much. LOL.
