2001 C5 Corvette
Old Dec 21, 2020 | 02:14 PM
fshaw1's Avatar
fshaw1
5th Gear
Default 2001 C5 Corvette
On 10/1/16 I bought 2001C5 Corvette with 70,000 miles on it..I put 4 new tires on it...it now has 82,ooo miles on it ..how long can I safely drive on these tires?
Old Dec 21, 2020 | 02:21 PM
WalterSobchak's Avatar
WalterSobchak
Years. You're fine right now. I assume you aren't doing a track day.
Old Dec 21, 2020 | 02:22 PM
Bill17601's Avatar
Bill17601
AIR FORCE VETERAN
It all depends on how hard you use the tires. It’s easy to wear tread off lapping the car, drifting the car, or doing burn outs. Just stop by any tire shop and have them looked at for free.
Old Dec 21, 2020 | 02:26 PM
fshaw1's Avatar
fshaw1
5th Gear
I put about 500 miles a month on tires..no burnouts or hazardous driving...thanks for input...
Old Dec 21, 2020 | 02:44 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
So it does depend on the tire (and how you drive as others have said). Tires in general are good for about 6 years (based purely on age) as long as the tread is still good. Also as a general rule the stickier a tire is the less time it will last. So if you have high performance Summer tires they won't last as long (but will perform better in warm weather) Most high end performance tires are rated to last around 30K miles. Tires designed to last a long time can go 80K miles (but will not be good for performance driving). What kind of tires did you put on the car, and what is the date code on the tires? This will help us to better answer your question. Based on the fact that you drive 500 miles a month and don't do burnouts or the like, your tires should last at least 5 years. If the tread still looks good after that, you can possibly get another year out of them. After 6 years, I would replace them even if the tread is still good.
Old Dec 21, 2020 | 03:02 PM
Toys4Life C5's Avatar
Toys4Life C5
St. Jude Donor '21
I am only half kidding about this.
I propose you go do some burnouts, then swap front to rear and do some more burnouts - not be reckless, but to get through the hard layer of rubber down to some softer stuff.
Any rubber experts on the forum. Is there any truth to my suggestion?
Toys
Old Dec 22, 2020 | 10:50 AM
grinder11's Avatar
grinder11
Only 2 things really determine tire life, assuming they're maintained with correct pressure.
1: driving style.
2: type of tire/rubber durometer, or hardness.
I have 25,000 miles on my Goodyear Supercar tires, and there's probably another 25,000 miles on them. Most people don't get that kind of mileage out of them. But I'm almost 67 years old, not almost 27!!! Driving style. But I'll guarantee you if I had Drag Radials, there's no way I'd still have them on at 25,000 miles!!! Durometer, or rubber hardness/softness, matters too. Without knowing how you drive, or what tires you have, it is impossible to estimate tire life...
Old Dec 22, 2020 | 02:31 PM
Joe Scafide's Avatar
Joe Scafide
Default Tires
Are they run craps ?
Old Dec 22, 2020 | 03:15 PM
c5arlen's Avatar
c5arlen
How long can I drive on these tires?
Jeez.
First.... are tires "run flats" and what manufacturer?
Number one question presently is... what brand, size, and model tire?
Number two question is... what are the date codes on each tire?
Number three question is... Is the "ware bar" showing ware and how much?
If you know these answers, you can answer your own questions about your own tires.
If you drive a Corvette you should know this..... If not, learn it. 😠
Old Dec 22, 2020 | 04:54 PM
MWWarlord's Avatar
MWWarlord
Jeez.
OP is a new member who is trying to learn.
Old Dec 22, 2020 | 05:24 PM
I’d say 2-3 more years or so. I usually keep tires for about 6-7 years before swapping them out.
Old Dec 22, 2020 | 07:36 PM
bonesbrakr's Avatar
bonesbrakr
You have to change them every 1,000 miles.
Old Dec 23, 2020 | 09:29 AM
grinder11's Avatar
grinder11
Not to paraphrase Biden, but C'mon, man!!
Old Dec 23, 2020 | 10:10 AM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
You would be surprised how many people know absolutely nothing about tires. It's a shame that not everyone could just come out knowing everything like you do - then we wouldn't need a forum.
OP - What tires did you put on the car? Generally accepted time of replacement is 6-7 years regardless of miles, and most tire shops won't touch a tire that's older than that for liability reasons.
Old Dec 23, 2020 | 02:44 PM
c5arlen's Avatar
c5arlen
You are correct. My bad.. Sorry 😩
To 2001 C5 Corvette
