I have the speed engineering headers. The fit great and perform good. I did not use the xpipe that came with the kit. I already had magnaflow xpipe and exhaust. I had my buddy at his muffler shop weld it up. I would definitely buy the speed engineering header again for a budget build.
"Cheapest" I would go is TPS or Hinson headers. I run TPS 1 7/8" with ZERO fitment issues to AC lines or steering shaft and tuck up very high for ground clearance. Drop right in without disconnecting anything.
No ebay/Texas Speed/OBX/Speed Engineering.
The performance gains between a Kooks/ARH/SW and a Hinson/TPS is not worth the added cost since all will have good fitment IMO. Once you get into TSP/ebay stuff performance may suffer more AND you have the risk of fitment issues. The gains simply going to a LT header WILL be noticeable whether it be a cheap header or expensive one.
You are paying for quality stainless material and quality control fitment the higher you go up the price range. So prioritize performance/fitment/cost however you like.
TPS headers are what I was considering doing for my 2007 auto as well. They have some good deals often so I am just waiting got them to offer another sale and I think I am going to pull the trigger.
Speed Engineering headers don't have fitment issues. Plus they work.
i have been comparing all the long tubes for the last 6 months. most of them look the same. not much at all different. just mostly in the collector area.just had a set of 1 3/4 s.s lt delivered to my door for 260. they look very good. my nephew is a pro. tig welder and i had him look at the welds and he said they looked very good. i have had cheap headers go on very easy and very expensive ones be a pita. do your homework and watch the many videos about the install. it got to the point where i copied about a dozen pics.of different lt's of c5 headers and compared them to each other and could not find a dimes worth of difference. buy what makes you feel good about the purchase.
the headers in the y-tube video you posted look like mid length headers. mine and many other e-bay headers are much longer. i like his videos anyway. watch where the collector ends up with long tubes. long tube headers have the collector extend into the factory cat. area which i did not like. wanted to use my factory cats. will have to spring for a couple aftermarket cats. now extra hundred bucks i wanted to avoid.
