If they are glued on, don't mess with them at all. Buy a set on the used parts forum or Ebay, then sell them to someone else via the same route. For every 4 or 5 of us embarrassed by the look, there is one who found it attractive.
Like others have mentioned a heat gun or hair dryer to remove those hideous things. Then either goo gone or WD40 should help you rub the adhesive off without marring the lenses. Don't use a razer blade. Just the goo gone or WD40, a rag and some elbow grease.
Originally Posted by LSgoBRRRView Post
Good move, those are pure rice. I don't even know if I could drive it home like that, it's a Vette not a beat up fart canned Civic!
Originally Posted by StingrooView Post Unscrew the tail lights on the bench and use heat and some fishing line to pull them off, if they are adhesive backed.
And may the Flying Spaghetti Monster bless you for removing those atrocities. >>>>>>>>>>>>>>>>>>>>>>>>> but
======================================== ======================= Quote: Originally Posted by Johnny HardcoreView Post Like others have mentioned a heat gun or hair dryer to remove those hideous things. Then either goo gone or WD40 should help you rub the adhesive off without marring the lenses. Don't use a razer blade. Just the goo gone or WD40, a rag and some elbow grease.
Yello95 ...maybe tape an M-80 to each one ?
Second thought...i sorta like them in a strange way....
