limited slip
Old Jan 31, 2021 | 05:37 AM
6Gxray's Avatar
6Gxray
Cruising
Default limited slip
So when I get on my throttle hard not really hammered it seems as though I can feel the right wheel pulling a little harder than the left.I can feel the rear of the car seem to pull to one side slightly. Could it be shocks,or the rear slip clutch plates being worn.its a 2004 with 50K miles hard to believe it would be the diff
Old Jan 31, 2021 | 08:45 AM
RedTRex's Avatar
RedTRex
It's natural for the car to walk to the right if the LSD is working properly. Nontheless, you can do a "breakway torque" test to see where your diff is at.
Old Jan 31, 2021 | 09:31 AM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Old Jan 31, 2021 | 12:00 PM
Speed25's Avatar
Speed25
Rear alignment issues will do that, too.
Old Jan 31, 2021 | 05:17 PM
6Gxray's Avatar
6Gxray
Cruising
how do you do a break away torque test
Old Jan 31, 2021 | 05:24 PM
6Gxray's Avatar
6Gxray
Cruising
just watched a vid on it thanks
Old Feb 2, 2021 | 10:01 AM
MetalMan2's Avatar
MetalMan2
Some videos on testing breakaway torque are wrong, FYI... Here's a good thread on the topic which I suggest reading through completely: https://www.corvetteforum.com/forums...-question.html
To limited slip
