Differential Question
Old Aug 16, 2020 | 10:50 AM
Zeds06's Avatar
Zeds06
Default Differential Question
Looking for some help.
I bought a C5Z from a friend as a project CAM-S car for SCCA Autocross.
The car has Heads, Cam, Intake , and lots of other mods by previous owners, I have receipts and history for some of the work but not all.
Just trying to catalog a baseline with that car, I was going to perform a break-away test on the rear end to see if the diff was still good.
I followed Froggys guide on Youtube, and could not get the wheel that was in the air to breakaway even 200lb-ft + of applicaiton. I Decided I did not want to put anymore load on the diff.
I tried both passenger and drivers rear wheels, making sure I was in-gear, with parking break off.
This got me thinking, I wonder if this car does not have a factory diff?
Sharp circles in a parking not have no issues, and both tires hook up on hard launches.
Any idea of how to confirm what LSD I have without cracking the casing open??
Thanks for any guidance on this.
Old Aug 16, 2020 | 10:58 AM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
You’ll have to open the case to determine if it’s been changed. Might be just a rebuilt with factory clutch packs, or an Eaton piece. Either way, I don’t think I’d sweat it at all... Seems like it’s good to go for your setup.
Old Aug 16, 2020 | 11:00 AM
helga203's Avatar
helga203
What do you mean break the wheel loose. They don't rotate??
Old Aug 16, 2020 | 06:18 PM
Zeds06's Avatar
Zeds06
Following the Froggy method, pretty common way of testing clutchpack LSD, I could not get the wheel that is in the air to rotate. After I maxed out my torque wrench I put a breaker bar on and turned as hard as I dared and nothing.
I am not worried about it being broken since it seems to operate as it should, I am just more curious as to whats in there for reference when I am testing and setting up the car.
Thanks!
Old Aug 16, 2020 | 10:30 PM
MetalMan2's Avatar
MetalMan2
Take it out of gear, and try. That's the proper way to test breakaway torque. Otherwise you're fighting engine compression.
FYI, supposedly when refreshed, the LSD should be somewhere in the neighborhood of 100-150 ft-lbs breakaway torque. If your not-newly-refreshed LSD is exceeding that then either there's something wrong with it, or the test method.
Old Aug 17, 2020 | 06:46 AM
Zeds06's Avatar
Zeds06
with it out of gear, i can rotate the wheel by hand. That doesnt seem right.
Old Aug 17, 2020 | 06:55 AM
Zeds06's Avatar
Zeds06
This is the proceedure I followed.
Old Aug 17, 2020 | 09:22 AM
helga203's Avatar
helga203
https://www.youtube.com/watch?v=QK2yCUd4X6A&t=108s
Maybe you have some heavy duty bellevue spring.
Old Aug 17, 2020 | 10:47 AM
MetalMan2's Avatar
MetalMan2
You're right, it's not. My Z06 with 70k, spun freely by hand when tested *out of gear*, and these were what remained of the belleville springs that came out of the LSD (new C6 Z06 spring on left for reference):
And the clutch packs were TOAST:
I did a rebuild of the LSD using C6 Z06 clutch packs and belleville springs.
Just because it's on the internet, doesn't mean it's right
Think about it: if you have one drive wheel on the ground, trans in gear, and you're turning the free wheel, you're spinning the trans and the engine as well. So you're not succeeding to turn it because you're fighting engine compression. If you put the trans in a higher gear I bet you'd find less resistance to spinning the wheel.
Old Aug 17, 2020 | 10:56 AM
Zeds06's Avatar
Zeds06
Maybe I am thinking about this wrong . . . But with the trans in Neutral, and one wheel in the air, wouldnt i be able to turn the wheel in the air freely with or without the LSD being faulty? I would just be spinning the trans and torque tube at that point in time? I guess i need to pull the diff out and take a look see. . .
Old Aug 17, 2020 | 10:59 AM
Zeds06's Avatar
Zeds06
Do you have a list of part numbers and cost you used in your rebuild?
Old Aug 17, 2020 | 11:07 AM
MetalMan2's Avatar
MetalMan2
That's how an open differential works, which mine was with the broken belleville springs. With trans in neutral and a wheel spinning freely, you're spinning the output shaft of the trans but the input shaft of the trans won't be spinning (and thus the torque tube also isn't spinning).
The LSD puts a load against the clutch packs (friction disks), so spinning one wheel against the other will have resistance with or without trans in gear.
FWIW: if you lift up the whole rear of the car and put the trans in gear, if your LSD has failed then when you spin one wheel the other wheel will spin the opposite and without resistance.
Yes:
  • 2x C6 Z06 clutch packs: GM 19132906 (they are sold as 1 each)
  • 2x C6 Z06 belleville springs: GM 19132817 (they are sold as 1 each)
Recommended:
  • 2x side cover O-rings GM 89047953 (they are sold as 1 each)
  • 2x output shaft seals GM 88996703 (they are sold as 1 each)
Old Aug 17, 2020 | 11:10 AM
Zeds06's Avatar
Zeds06
Makes sense when i think about it now. . . I will try some more diagnosis. Really appreciate your time and input here.
Old Aug 17, 2020 | 12:45 PM
Zeds06's Avatar
Zeds06
Just another piece of the puzzle.
It will lay down two equal length and healthy black marks on launch.
Old Aug 17, 2020 | 01:27 PM
MetalMan2's Avatar
MetalMan2
If I can remember, later today I'll see about putting up a rear corner of my Z06, with trans in neutral, and test breakaway torque on the rebuilt LSD that will have about 80 miles on it.
Old Aug 17, 2020 | 01:33 PM
Zeds06's Avatar
Zeds06
That would be really helpful!
Old Aug 18, 2020 | 02:17 AM
MetalMan2's Avatar
MetalMan2
Okay, I was able to make 5 minutes to check it out.
Driver-rear wheel off the ground, e-brake off, trans in neutral.
Torque wrench on a lug nut, oriented to mimic torque being applied to the axle nut.
Started at 60 ft-lbs and worked my way up to 100 ft-lbs. The wheel never slipped even at 100 ft-lbs. I didn't go any higher because that's the limit for the lug nuts.
Keep in mind this same test, pre-LSD-rebuild, the wheel spun freely.
To Differential Question
Old Aug 18, 2020 | 07:48 AM
Zeds06's Avatar
Zeds06
Guess this answers my questions! Thank you for your help and time! Still weird that both wheels put power down on launch. guess I will be removing my diff.
Old Aug 18, 2020 | 11:13 AM
MetalMan2's Avatar
MetalMan2
I had bought the side gear compressor tool (to be used with a press), which is Kent Moore J-42162. My old belleville springs were so bad that the tool was unnecessary to disassemble the diff. But it's definitely needed for reassembly. I'd be happy to lend or sell my tool if you're interested... with any luck I shouldn't need it for a long time.
Old Aug 18, 2020 | 12:40 PM
Zeds06's Avatar
Zeds06
what would you be interested in selling for? shipping is 29841
