I just bought some MRR m755 wheels (18x9.5 and 19x11) for my car. From all of my research I have found the tire sizes for the wheels if I were to run summer tires like 305/30r19 and 265/35r18. I have thought about looking into all season tires (maybe brand too) and wonder which tire sizes would be best?
They do three things, marginally at best. You'd be better off getting a summer tire for the nice wheels and a winter tire for the others, if you think you'll drive in cold temperatures often. Plus, it will keep your nice wheels nicer for longer.
I'm running 275/35R18's on the front and 305/35R19's on the back. Love the way they look and drive. Be prepared to adjust your speedometer though, I did because I hate guessing.
I wouldn't run a 305/35. That's over an inch taller than a 305/30.
You'll barely need to worry about the speedometer.
275/40R18 to 305/30R19 is a 2% difference. At an indicated 70mph, you're traveling 68.7mph. Nothing to lose sleep over. Unless you already have HPTuners and can do it yourself, I wouldn't pay money for that minuscule difference.
Punk...I went with the Pole Position tire over the continental. Most of the reviews say the sidewall is better in the pole position tire over the continental. Everyday driving you probably won’t notice a difference. I can’t comment on it yet, only have about 200 miles on the setup. Currently have 4-5 foot piles of snow at the end of the driveway, not going to test it out anytime soon.
Lots of people run a 265/35/18 and many run a 275/35/18, also. The 265/35/18 is right at 1" shorter than the 305/30/19 rear which keeps the sidewall heights close to the same. Some people like Sean and Wayne are running a 275/35/18 front and 305/35/19 rear. About the only downsides to a 305/35 is less tire selection/higher cost but if you need the taller sidewall & height, nothing wrong with that combo, either.
I went with a 265/35/18 front and 305/30/19 combo on my car, before I went widebody.
265/40R18 and 305/35R19 will have the same size sidewall if that matters to you, and will retain a roughly 1-inch diameter difference to keep the computer happy.
Computer doesn't care, as long as the front tires aren't taller than the rears.
