I have a 2002 Base. My question involves raising the front end to avoid the scraping when I use my driveway. I live in a HOA community so calling in a drone strike is not an option. I was wondering what, if any options are available. The car came with two rollers attached but they don't do the trick.
You could adjust the "lowering bolts" on the leaf spring up. That will raise the front up.
Also, always tackle bumps at an angle. I had to do this at my old house.
Honestly, scraping is normal for these cars, probably just your wind deflector, which is designed to give way via springs and pivot point. As long as its not your radiator supports scraping, I'd say you'd be fine.
Yeah as others have said - best to see what part is scraping. If it's the deflector, that's normal - they're consumable. If it's the bumper itself, try backing in or raise the front with the leaf spring bolts (jack up car, jack up suspension to release tension on bolt, turn).
Don't enter your driveway straight on, bring the front in at a sharp angle then straighten out, helps a lot.
If that doesn't cut it, I'd get the curb filling bridge piece
