If it were me, I’d put your old bulbs back in, make sure your car works normal, and send the LED’s back to Amazon and try another ‘Chinese’ brand off Amazon.
Hyperflash installed. What is weird is they don't flash at all only solid and the front dont blink either. Put stock back in tail light and front and rear blink. The fronts are switch backs. Never had any issue with them for the 3 years they have been in.
Any ideas would be great.
I’m not by any stretch a mechanic, even less an electrician, but try and follow process of elimination.
Id take the Hyperflash out and put the led bulbs back in, and see if they at least flash fast. If so maybe it’s the Hyperflash. If they still don’t flash at all then take them out and head to the nearest Kohl’s & order a new set of LED’s.
Going to try a lower amp relay. Since it is not hyperflash but no flash at all. The relay could be not seeing enough power. I will report back if it fixed it.
