Harmonic Balancer Cost
Old Mar 27, 2021 | 02:37 PM
djohn3853's Avatar
djohn3853
St. Jude Donor '21
Default Harmonic Balancer Cost
I just looked at my hb for the first time with the motor running and saw a slight wobble. Should there be zero wobble? or is a little normal?
Anyway, if I have to have this repair done what should I expect to pay? That's both parts and labor.
I think i've seen recommendations here to not get the oem unit, but I forget which one people do recommend.
Dave
Popular Reply
Mar 27, 2021, 02:45 PM
Toys4Life C5's Avatar
Toys4Life C5
St. Jude Donor '21
Powerbond balancer works great IMO.
Here is how to tell if yours is bad - OR NOT. EASY Peasey.
Old Mar 27, 2021 | 02:45 PM
Toys4Life C5
St. Jude Donor '21
Old Mar 27, 2021 | 02:48 PM
Oplinger9's Avatar
Oplinger9
Dave
I believe I payed around 1000-1200 can’t quite remember. That was for everything
Old Mar 27, 2021 | 05:56 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
https://youtu.be/IrXbaPC797k
thanks for posting! Good info and the video was a plus!
Old Mar 27, 2021 | 06:16 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Not to be sarcastic, but for that kind of money, I hope you got a GOOD balancer....maybe like an ATI.
Old Mar 27, 2021 | 06:20 PM
Rexde1's Avatar
Rexde1
I paid 850 for an ATI and belt installed.
Old Mar 27, 2021 | 07:42 PM
chilnviln's Avatar
chilnviln
Just for the balancer it would've come to aboot $1200 total. I also had to bring the Corvette to another shop for alignment since they are not equipped to do low cars and they removed the steering rack.
Mind you this is just a general shop that does all vehicles and in Northern California.
$780 Labor
$325 Balancer
$100 Alignment
$11 Crank bolt
$4 Brake cleaner
Old Mar 28, 2021 | 10:39 AM
djohn3853's Avatar
djohn3853
St. Jude Donor '21
Thanks everyone, especially Toys4Life for the video. I think mine might be slightly more wobbly than his, but I'd have to go look again. I'll also try the show polish trick to see if its moving.
Also, what about pinning? Is it a smart thing to do if you're installing a new one anyway? and i suppose this is additional cost.
Dave
Old Mar 28, 2021 | 11:22 AM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
Dave
Pretty simple really. If you are NEVER going to add a belt driven supercharger then don't bother especially if you are paying someone else labor. Pinning the crank on a mild or stock LS engine is pointless for the most part.
Now, don't do like I did. I had my engine all torn apart for cnc heads and a cam change with a new balancer. Had the rack out and everything. I convinced myself at the time that I was never going to supercharge and that got me out of pinning the crank.
Fast forward a year and a half. I now have a belt driven supercharger and yes I had to go in and redo half the job only doing it this way was even more of a pain in the *** as there's more stuff in the way compared to when I should have done it originally.
If you are paying labor it could add 200 bucks to the job factoring in the pin kit with that.
Old Mar 29, 2021 | 09:10 AM
MCruz's Avatar
MCruz
8th Gear
The dealer quoted me $1500 total, I called a few corvette shops and the quoted me more than the dealer.
Old Mar 29, 2021 | 09:12 AM
Chris_G's Avatar
Chris_G
St. Jude Donor '05-'06-'07
$1400 with new belts, tensioners, crank seal, plus parts.
Old Mar 29, 2021 | 09:30 AM
leadfoot4's Avatar
leadfoot4
You mean PLUS the cost of a balancer???
Old Mar 29, 2021 | 12:50 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
I would recommend pinning regardless of if you're going to add a supercharger later. Pinning will ensure that you NEVER have to replace your balancer again. Check out this video.
http://www.bing.com/videos/search?q=...6FORM%3DHDRSC4
Old Mar 29, 2021 | 01:19 PM
cherokee433FL's Avatar
cherokee433FL
On my 2002 c5, i paid roughly $1100 for the complete job for a balancer remove and replace. that included the new powerbond racing balancer, and took about 3 days to do the job without taking the front end apart. that is with a 25000 mile and 2 year warranty. it runs great without any problems since.
Old Mar 29, 2021 | 04:48 PM
bonesbrakr's Avatar
bonesbrakr
One arm below the elbow and one leg below the knee.
Old Mar 29, 2021 | 06:06 PM
grinder11's Avatar
grinder11
X2!! The worst part of the entire balancer job is getting to it!!! Once you're there, not to insult anyone, but it's kind of a no brainer. Even if YOU never run a blower, whenever you do decide to sell it someday, it's an added selling point to the new owner, especially if he wants to add a blower......
Old Mar 29, 2021 | 07:16 PM
Mr. Black's Avatar
Mr. Black
That's pretty funny. Don't get me wrong, I like Lyle and his videos. That is a very rare failure. Like you have a better chance of getting hit by lightning.
Also If you pin a cheap balancer that doesn't mean you won't ever have to do it again. Pinning the crank doesn't ensure the outer ring won't come loose.
I wouldn't pin a customers crank unless they requested it.
I mean where do we draw the line? There are more dead LS motors out there because of simple oil pump failure. Do we change the oil pump while we're in there? how about the timing chain?
Most guys just want to get their car running again. Some others like to take everything to the max and there's nothing wrong with that but saying it has to be done is a little over the top IMO.
I know what we all say about opinions though.
To Harmonic Balancer Cost
Old Mar 29, 2021 | 08:55 PM
VAvette98's Avatar
VAvette98
I had a Chevy dealer here in VA install the ATI balancer and new tensioner, idler pulley, and new belts (I supplied all the parts) for like $670.
Old Mar 30, 2021 | 08:06 AM
leadfoot4's Avatar
leadfoot4
Originally Posted by cherokee433FL
.....and took about 3 days to do the job without taking the front end apart.
That long? That's about the same amount of time that I took, while leisurely working by myself, AND I pulled the front cover to replace the timing chain and pin the crank, "just because I was in there"........
Old Mar 30, 2021 | 08:33 AM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
Damn I must have got a crazy deal on mine then. I paid $300 in labor and brought my own Summit balancer. lol
