Hi, I want to install a battery mat but when l remove the battery would l have to reset the radio stations? Would l also get crazy dashboard lights as well? I will get a AGM one day but for now this battery is 2 years old.Thank you in advance.
Yep, I lose my stations (although I rarely listen to the radio) when I change batteries. But never had the "crazy dashboard lights" issue you refer to when I did change batteries.
Before disconnecting the battery you connect this into your cigarette lighter. You can purchase one of these https://www.ebay.com/itm/Kastar-295A...53.m2749.l2649 You probably can find one cheaper if you search awhile. The 9 volt battery will keep all your presets intact.
Yup, I cant explain why but I have had no problems from brief (ten minutes) disconnecting the battery....everything was fine, no resets needed.
Longer disconnects......yup.
