Harmonic Balancer replacement cost - $5,000 dollars - W.T.F
Old Apr 9, 2021 | 12:36 PM
ArcticWhite98_'s Avatar
ArcticWhite98_
Default Harmonic Balancer replacement cost - $5,000 dollars - W.T.F
So I took my '98 in for an oil change, also set up an appointment for a belt change. Anyway, they checked out the engine and pointed out something seemed off about my harmonic balancer and that because it's a ''30 Hour Job'' & they gotta take out the engine, it would cost me around 5,000 dollars to replace it, this completely caught me off guard. Is this really what it normally costs?
Popular Reply
Apr 9, 2021, 01:30 PM
TrackAire's Avatar
TrackAire
I think it is only fair to your Vette brothers to name this shop so others can avoid it.
Old Apr 9, 2021 | 12:39 PM
MikeTN77's Avatar
MikeTN77
Run. That is just absurd. Engine does not have to come out. Steering rack has to be dropped, shop just quoted me 300 bux labor and that's with a crank seal change ( I would do that while you're in there)
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
Don't ever go back to that shop again. I think they gave you that price to either rip you off or make you go elsewhere because they didn't want to work on your car.
Plan on anywhere from 700 to 1200 average IMO.
Also you might want to verify it's bad for yourself.
Old Apr 9, 2021 | 12:49 PM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Old Apr 9, 2021 | 01:00 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
$5K is not even CLOSE to reasonable for this job! Run away and NEVER come back!!!
Old Apr 9, 2021 | 01:10 PM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
That is laughably bad.
Old Apr 9, 2021 | 01:30 PM
TrackAire's Avatar
TrackAire
Old Apr 9, 2021 | 02:33 PM
slapshot12's Avatar
slapshot12
Veteran: Coast Guard
I had mine changed to an ATI and it was just under $1k, the balancer itself was around $440, the ARP bolt was $30, the oil seal behind the balancer was under $20, and I think 3-4 hrs of labor.
I'd run away from that shop and never return, they're trying to rip you off. The engine doesn't have to come out, you just drop the steering rack a little. If they are doing it that way, they don't know what they're doing.
Old Apr 9, 2021 | 02:38 PM
grinder11's Avatar
grinder11
Even at $125/hrs labor (which is a bit high, but just for discussion), I can't see this even coming close to $900.00 for just the labor. Sure, an ASP or ATI balancer, plus labor, would probably be over $1,200.00. But I agree with the post about them not wanting to work on your car, unless they somehow thought you looked like easy money. Also-Perhaps they really don't know how to replace the balancer any other way??!!! Like others said, RUN 🏃‍♂️🏃‍♀️🏃‍♂️!!!
Old Apr 9, 2021 | 02:41 PM
Chris_G's Avatar
Chris_G
St. Jude Donor '05-'06-'07
I had the HB, bolt, seal, belts and tensioners replaced and labor was $1400
Old Apr 9, 2021 | 03:44 PM
Hepcat's Avatar
Hepcat
Paid about $700. I know I was given a solid on the new balancer cost and looked like 5 hours labor. I only knew my balancer was "going" thanks to the forum and some videos showing normal versus not.
Old Apr 9, 2021 | 04:35 PM
ThomasR's Avatar
ThomasR
I can do it for $4,000.
I agree that they don't want to work on it.
Old Apr 9, 2021 | 05:03 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Its called free enterprise...under the sleepyjoe plan it will cost $10,000....so $5000 sounds pretty good right now...
Did they give you an estimate on the gas they will use to test drive it at joes $10/gallon?
BTW...going price to change a balancer including parts should be around $1200...
Old Apr 9, 2021 | 05:26 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Last time I did it was $160 and that included pinning the crank. My labor was free.
Oh forgot about $8 for beer.
Old Apr 9, 2021 | 05:39 PM
91LSMAN's Avatar
91LSMAN
I just had mine done-replaced with an ATI-and I spent just about $2,000 to have them replace the balancer, idler pulley, belts, replace the automatic transmission cable, etc. (I had some squeaks to get rid of and did some preventative maintenance at the same time)
Them telling you the engine needs to be pulled means 1 of 2 things:
#1-They are morons who actually think that.
#2-They wanted to see if you believed them and figured they could make some extra money.
Old Apr 9, 2021 | 05:56 PM
Smoken1's Avatar
Smoken1
No need to remove the engine or the cradle. It's right there in plain sight
Old Apr 9, 2021 | 10:01 PM
Corvette#2's Avatar
Corvette#2
A dealer quoted $1000 to do my harmonic balancer. So 5 grand - they are out of their mind.
I paid an independent shop 700 something to change mine.
To Harmonic Balancer replacement cost - $5,000 dollars - W.T.F
Old Apr 9, 2021 | 10:19 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
WOW.....you are the man......
Old Apr 9, 2021 | 11:32 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
^ beer, a selection of tools, and the cheapskate/gearhead thought process make it happen.
Old Apr 9, 2021 | 11:43 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
The best advice I can offer that may save hours.... once the steering rack is free of both knuckles, etc, is to move it fully towards the passenger side of the car so it’s sticking out the fender by a foot or better..... looking down from top, the driver side tie rod is sitting there about where the balancer is... rotate it upward, then slide the steering rack halfway back to the driver side as that upward rotated arm heads northward out of the engine bay.
Struggled like you wouldn’t believe until that knowledge was found.
Fastest time is 20 minutes from car in the air to rack out of car.
