Learn TPMS sensors. Help
Old Apr 15, 2021 | 12:56 PM
ArtGle's Avatar
ArtGle
Veteran: Marine Corps
Default Learn TPMS sensors. Help
O.K., guys, My book #3 of my factory manuals appears to have disappeared somewhere.
Just had new tires mounted, and one sensor replaced.
Owner's manual is NO HELP... (See Dealer) !!!
anyone want to educate this idiot. I've done it before, but that was years ago...
And I did try to search the forum.
Thanks in advance.
Popular Reply
Apr 15, 2021, 01:04 PM
jcgunn's Avatar
jcgunn
1) Turn ignition on
2) Press "Reset" button in order to clear any IPC display warning messages
3) Press and release the "Options" button on the DIC to scroll through the display options until the IPC display is blank
4) Press and hold the DIC "Reset" button for 3 seconds
5) Press the "Options" button again until TIRE TRAINING message appears
6) Press "Reset" button until the IPC "Learn L Front Tire" message appears in order to begin the programming
7) Install the J41760 Tire Pressure Monitor (TPM) System Programming Tool (a large magnet will do) over the left front valve stem
8) The horn will sound, indicating the left front TPM sensor is programmed (if this takes more than 15 seconds, pull magnet back and try again, it will give you three tries. Then you must start over)
9) When the horn sounds, proceed to program the next TPM sensor in the following order as directed by the IPC messages: -Learn R Front Tire -Learn R Rear Tire -Learn L Rear Tire Programming can be canceled by turning ignition off, waiting 2 minutes with no sensors being learned, finishing all 4 wheels or through the DIC. If the programming is canceled with less than 4 sensors learned, it will only accept the codes programmed up to that point
Old Apr 15, 2021 | 01:04 PM
jcgunn's Avatar
jcgunn
1) Turn ignition on
Old Apr 15, 2021 | 01:57 PM
Exactly the procedure to follow.
Old Apr 15, 2021 | 02:14 PM
Smoken1's Avatar
Smoken1
Buy a Tech2 and remove that feature
Old Apr 15, 2021 | 02:29 PM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
I use a magnet from an old 6.5" woofer to learn mine.
Well, I did before I turned it off like Smoken1 suggested.
Old Apr 16, 2021 | 07:32 AM
dskinsler83's Avatar
dskinsler83
Id love to turn mine off. Tried a VGDiag but dont have a win7 computer left and didnt wanna go through the what seemed like a major hassle to TRY and get it to work.
Old Apr 16, 2021 | 11:47 AM
grinder11's Avatar
grinder11
Another good, and very strong magnet to use, is the 'donut' style used in auto trans pans to grab metal shavings. They fit right down on the wheel, with the valve stem sticking up thru the hole in the middle. Trans repair shops would probably give you one free, as they probably have them coming out their proverbial yang yangs!!
To Learn TPMS sensors. Help
