50th anniversary -questions
New to the forum and have a 50th anniversary convertible that was my fathers. Car is an auto and only has 7100 miles.
What is everyone's thoughts on keeping the miles low vs enjoying it. Not that I would use it as a daily driver, but would like to take some road trips while still being mileage conscience.
Also, what are you thoughts on modification vs the car value? Not talking any permanent type mods, but ones that can be reversed easily and keeping the original part (like exhaust). It will need tires as the mfg date are over 10 years I believe as I think my father had them swapped once and went with the Eagle F1's. They seems to be getting a hard compound though and probably would be a good thing to change them. The original Eagles are getting hard to come by it seems lately so how do different tires affect value to a true collector if we part with it down the road?
The asking prices on these models seem to be all over the map depending on mileage and condition so it is hard to get an idea of a good value.
Just have fun, whatever that looks like. I also enjoy updating and modernizing mine a bit (led lighting, new tail lights and turn signal housing, etc). Everything I've done has kept with the beautiful original design choices of the development team, just a bit more modern now. And go with Michelin Pilot Sport AS ZP tires.
Don't forget to SAVE THE WAVE!!
On my car, I chose to take off the Run Flats. They became noisy and bumpy. I researched around and found that there are some non-run flats that would be good for me. I chose General G-Max. Now that being said.....while you changing the tires, install a new set of TPMS. I failed to do that, thinking that the old would work, WRONG! I'm now in the process of having my tire guys break down the new tires and install a new set of sensors.
"Happy Motoring and See The USA". For those who are old enough to remember this saying
Have looked at run flats and non-run flats. Only thing of concern would be a road trip without a spare and possibly being stranded. Considered looking into some type of spare option similar to a very small factory type option to strap in for long trips (like Route 66), but not finding much out there.
Going to start with the above before thinking of any modifications. Exhaust would be nice at some point and have been a big fan of Magnaflow on other vehicles, but have heard a few with Corsa Sport exhausts that sound nice as well.
Just wish it was a 6 spd car!
But beggers cant be choosers especially since he won it at a church raffle.
So... is a 50th AE collectable? Would it hold a premium over other C5's, short of maybe a Z06? Unfortunately NO!
Let me explain. These will be generally round numbers and not exact but close enough. All 2003 were 50th Anniversary cars but only a portion of the years production were AE's. There were 15 thousand AE cars produced, divided almost 50/50 between coupes and convertibles, so 7500 each.
So looking at those numbers, you can say "I have a 1 of 7500"...that is still a large number that won't make the car 'worth' more.
Trying to break that 7500 down even more doesn't help. All AE's came as a standard package that included options that were available on earlier models, ie: HUD. There were some options that started with the AE's that continued on with the later cars, ie: the F55 handling.
So far the only thing I have found that might be an option to be able to change at the time of purchasing new was the G90 (or G92, I forget off of the top of my head) performance axel ratio from the standard 2.43 to 3.15 for cars with an automatic transmission. I can't confirm this to be an option or standard with the AE package.
One other thing is a manual or automatic transmission. I have found some conflicting numbers as to total production numbers on how many cars had either transmission, but most sites I have researched seem to show an even split between the two across both coupes and convertibles. On this I could be wrong!
At best with a manual, convertible you might break down to a '1 of 3,250'. This is a far cry from anything you could call 'rare'!
There are a couple of caveats to owning an AE. The one year only paint and interior colors. Trying to find something to match the paint color if you need something for the outside of the car, as in does the state you live in requires you to have a front license plate? There is a factory plate surround for the front and you can get a black one and paint it. Hopefully it matches! Want to make changes in the interior? Like put in a double din stereo, change seats to something more supporting, different steering wheel to add steering wheel controls for the stereo. You can get all of the parts but then you will need to dye, paint, have custom covers made...ect, if you want to keep the colors matching the original.
So, with all of that stated, you'll never see any AE cross the block at Barrett Jackson that brings a 'six figure number'! No matter how nice it is, how low miles it might have, ect. Just to many made! Now you might get a bump in value if you find someone who just has to have an AE, for whatever reason, that might get you a couple of thousand over a non AE. Remember this also, "Nothing is worth anything until someone is willing to give you something for it"!
As for doing modifications, sky's the limit! Change the exhaust? I think the cars need to sound like a Corvette and not a Cadillac. Want to add more power? The old saying of "Speed costs money, how fast can you afford to go"? You won't be killing your value unless you go off the deep end. It might be harder to find someone who wants a supercharged, cam and headed, nitrous car, but there are people out there that do! Just plan on NOT getting the money back that you send on modification.
I say do the normal maintenance on it to start with, belt, hoses, fluids, especially tires if they are old whether they are worn or not, and DRIVE IT to start with. Enjoy the car as it is then start in to modify it to make it 'yours'!!!
