2001 C5 Clutch Replacement
Old Apr 23, 2021 | 05:56 PM
Jason Clark's Avatar
Jason Clark
Default 2001 C5 Clutch Replacement
Well, I replaced my clutch master cylinder with a Tick unit and i still get dead pedal and no engagement. It looks like I am in for a slave cylinder, and might as well do the clutch assembly while it is apart. The car is stock and street driven mostly (want to try auto cross). Any recommendations on a replacement setup? I do not plan on adding any major power modifications anytime soon. Thank you!
Old Apr 23, 2021 | 06:17 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
McLeod RST reuses your stock flywheel. Dual clutch with stock manners that will hold 800hp. Lighter than LS1 and much lighter than LS7/LS2flywheel combo. Plus the weight is closer to the centerline of rotation.
They cost around $750.
Old Apr 23, 2021 | 08:35 PM
gmanflying's Avatar
gmanflying
I'm going with Monster.
Monster S Series Single Disc (monsterclutches.com)
Old Apr 23, 2021 | 09:39 PM
rjacobs's Avatar
rjacobs
LUK kits are about 250 bucks. NOT saying LUK is the OEM for the factory clutch, but they are the OEM for a LOT of factory clutches.
Add a new slave for $100. $350 or so in parts...
Otherwise I second the Monster S series.
Do a rear main seal while you are in there... $25...
Old Apr 23, 2021 | 09:52 PM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
Heard really good things about McLeod RST and Monster LT1-S. An LS7 clutch will work, but they are heavy. I like mine, but next time around I will pony up for something better.
Old Apr 23, 2021 | 09:54 PM
1wholikescars's Avatar
1wholikescars
I have the Mcleod in two of my cars now and I love them. They seem indestructible. I've done everything from drag racing, road, auto-x, and Land Speed without issues on mine.
Just as a feedback.
Also, pilot bearing couldn't hurt to be done as well.
Old Apr 24, 2021 | 03:37 AM
dskinsler83's Avatar
dskinsler83
LUK is the OEM for the Corvette C5. Get yourself a LUK LS7 kit and be done. Be in it for less than $600 for all of it.
he is and has said he doesnt plan on any big horse power adders and even then the LS7 clutch will hold most. I am putting 480s hp and 490s tq to the tire and it is holding up fine.
Old Apr 24, 2021 | 07:26 AM
frodo84's Avatar
frodo84
Uneducated autodidact
If you go with an LT-1s, they recommend a stock master, not a Tick master. That is a great clutch for higher hp, if you don't need it the LS-7 deal is hard to beat.
Old Apr 24, 2021 | 09:25 AM
Toys4Life C5's Avatar
Toys4Life C5
St. Jude Donor '21
Something to be aware of. Mark your original flywheel to crank relationship and hold on to your original FW/PP until you are completely satisfied with your new setup.
PS. 2 years here on the Monster LT1-s, new stock slave, re-used stock master.
To 2001 C5 Clutch Replacement
