Oxygen sensor check engine light
Had ARH long tube headers installed on my 2002 6 speed with a tune. I get the “slow response” codes for the front oxygen sensors now. Anyone else having this problem? What was the fix? With 90,000 on the odometer I had the sensors replaced with no change after a 10 mile ride.
Any suggestions?
Any suggestions?
I was recently wondering the same thing. I swapped the rears to the front locations with the same result. I watched the o2's with a scan tool and they seem to operate fine. I believe tuning the corresponding codes out is the only way
Moved to C5 Tech.
