window
Old May 29, 2021 | 08:43 PM
racereks's Avatar
racereks
1st Gear
Default window
Hi everyone I have a c5 convertable I live in florida and with the heat the rear window glue got hot and the window came out. I have tried 3 different epoxys and within a week all have come undun does anyone know of something to use for this tks
Old May 30, 2021 | 12:42 AM
Read up in these files:
Old May 30, 2021 | 06:38 PM
helphos's Avatar
helphos
Default Covertible rear window
I fixed my loose rear window last year with 3M Windowweld and it's still holding strong. You need to use 3M primer on it and then apply the Windowweld urethane and clamp it together. There are special clamps that use suction cups on the glass to apply pressure to the glued edge. Leave it clamped for 24 hours and you're done. It's the same stuff they use in windshields, so it won't be affected by Florida heat
Good Luck!
To window
