Using regular fuel while traveling......
Old Jun 5, 2021 | 12:09 AM
ThomasR's Avatar
ThomasR
I agree that the cost savings will be minimal.
In my area it's $2.99 for 87 and $3.59 for 93.
It costs me about $8 more per fill up. I'm okay with that.
Old Jun 5, 2021 | 02:39 AM
ClipperFan's Avatar
ClipperFan
I’d probably use jet fuel if they sold it at gas stations. Hope that helps
Old Jun 5, 2021 | 08:55 AM
C5MSG2004Vert's Avatar
C5MSG2004Vert
I am not OK with that. They are charging 20% more for a few octane. It is just a rip off. It used to be about 10 cents a gallon difference between the grades and the increase in gas mileage used to just about equal the price per mile. In some states you still have a much smaller price differential between the grades.
Old Jun 5, 2021 | 09:00 AM
grinder11's Avatar
grinder11
Originally Posted by Mickeyrx70
ChiliPepperGarage has a valid point. Even at $1/gallon difference, you’ll save a whopping $40 over a 1000 mile trip assuming 25 mpg. Not worth it in my view.
Except most built LS7s don't get 25mpg. Most. Mine is one of the most. I get around 20-21 on the freeway. However, this is off topic. My original question was is it possible to do this. It's becoming obvious to me that vehicles that require premium are in the minority. The government may also view people running premium as having deep pockets. In the near future, it may very well become reality that premium fuel will become $1.50-$2.00/gallon more than regular fuel. At this point, if you must pay for two separate tunes, it's probably not worth it. That would cost around $1,000.00, give or take. So I'm guessing you're correct (for now) that it may be doable, but it would take a long time to break even. Of course, the more you travel, and the lower your mileage, the quicker the return. I'm just trying to ascertain that it's doable........
Old Jun 5, 2021 | 10:34 AM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
While I know you're just joking it would end badly lol. Jet Fuel is akin to Diesel/kerosene.
Avgas isn't what it used to be way back when. Back in the 80s and 90s we used Avgas as poor mans race gas. The trick though was finding a fuel island attendant at the local airports that would look the other way and pump it into gas cans for us.
Old Jun 5, 2021 | 10:48 AM
wdcraig's Avatar
wdcraig
My wife and I took a 530 miles round trip road trip on Memorial day in our stock 2001 manual C5 convertible.. Even with a crosswind, some rain off and on and we drove through a couple of small towns; our car averaged 29.3 mpg on that trip (and my average speed for that trip was a bit over 70 mph). I'd also add that the Corvette has over 115,000 miles on it.
The Costco premium that day cost me $3.74 a gallon- its less now. Regular at that time was $3.14 a gallon. We used 18.08 gallons of premium on that trip for a total fuel cost of $64. Had I used regular and managed the same mpg (which of course is unlikely- because I owned a '97 Acura that recommended premium and I had experimented with that car and if that car indicative, I noticed mpg tends to drop with the lower octane, almost to the point of there being little or no cost savings); the regular fuel cost would have been just few cents shy of $57. So I paid $7 extra for the premium fuel.
I own a 2017 Lincoln Continental with the naturally aspirated 3.7 V-6 (same engine that was in the V-6 Mustangs) that I run regular in and it typically gets 26 mpg on the highway. Had we driven the Continental on the trip, we would have spent $62.80 for the fuel. Driving the 20 year old V-8 Corvette on premium fuel cost us less than $2 more than had we driven the 2017 Continental on regular.
Old Jun 5, 2021 | 12:18 PM
Westy R's Avatar
Westy R
If you were doing that in the 80s and 90s, you would probably have been getting 100-octane Low Lead. Yes, I said lead, as in tetra-ethyl lead. That is unchanged, because it's specified by the FAA. (Say goodbye to your catalytic converters.)
I had a Piper Tri-Pacer for quite a few years, and I was able to run it on 87-octane car gas until they mandated 10% ethanol in all grades. The ethanol would attack the hoses and gaskets in your fuel system, so I had to revert to 100LL -- which cost nearly twice as much as car gas. Oh, well.
Old Jun 5, 2021 | 01:47 PM
grinder11's Avatar
grinder11
Originally Posted by Westy R
The only conversion kit I've seen for the C5 is $900, plus the effort of installing it ... so if E85 were $1.00 cheaper per gallon than 93-octane (and the price difference is less in many markets), you'd have to burn 900 gallons of E85 to just-barely break even (and that assumes you installed it yourself). That's 22,500 miles of driving -- and I'll bet there are plenty of people on this forum who won't put 22,500 miles on their garage-queens in ten years or more.
I'm "politically opposed" to E85 made of Federally-subsidized corn-squeezin's. Consider this -- every gallon of Federally-subsidized car-fuel alcohol is one gallon less of High Fructose Corn Syrup for your sweet tea and high-calorie sodas. It also takes a gallon of moonshine out of the "liquid entertainment" market at your local Alcoholic Beverage Control store. (Okay, I'm sarcastic, but making ethanol fuel from corn is woefully inefficient; it's "34 percent efficient," which means it takes three gallons' worth of energy to produce one gallon of corn-ethanol fuel.)
That said, I'd better look at the political side of the problem, especially since EVERYTHING in these hyper-partisan times seems to "circle back" to politics! E85 is cheap because it's heavily subsidized, and I suppose it's blessed as "carbon neutral." Fossil fuel is scorned as "the spawn of the Devil," and the Wokerati are religiously-bound to curse the Petroleum Industry, even as they rely on it to fuel their transport to the next protest, the next riot.
My rationale for buying my Corvette was partially based on the notion that I'd better enjoy it while I can, before the Powers That Be tax it or regulate it out of my reach to enjoy it!
I know this is as far from the norm as it probably gets, but I once put 30,000 miles on my C5.......In 6 months!!! Actually, it was LESS than 6 months, because in Michigan, it was stored inside from November to April. So the miles I put on were in a small part of November, 2005, half of April, 2006, then May, June, July, August, and half of September. I then experienced a serious mechanical issue, one that would keep it off the road for several years...
Old Jun 5, 2021 | 02:00 PM
grinder11's Avatar
grinder11
When I bought AV gas back in the 80s for a Yoshimura engined Kawasaki 1,105cc Z1, the attendant told me it averaged 110-115 octane. Didn't ask about lead (bikes had no catalytic converters, then), but the attendant said he had no problem that the fuel wasn't for an airplane. What he DID have a problem with was using it on public roadways, and circumventing the fuel taxes. I assured him it was for off road,, on the strip racing, so there was no problem. Probably didn't hurt that the strip was only 2 miles away, and that I showed up with a gas can.
Old Jun 5, 2021 | 02:27 PM
Mr. Black's Avatar
Mr. Black
There were no cats on racecars. Well at least back then.
Also been down the car gas airplane stc road. My old man nearly crashed his grumman screwing around with car gas. It rains a lot here. Rain in your fuel can be deadly. Not the car gas directly but the handling and transport of it.
Old Jun 5, 2021 | 03:38 PM
ThomasR's Avatar
ThomasR
plus 10 cents more per gallon if you pay with credit.
Old Jun 5, 2021 | 09:36 PM
LTCHAPPA's Avatar
LTCHAPPA
I have used the middle grade 89 octane and the engine seemed like it had a miss once in a while under full throttle. I filled it up with premium and some fuel injector cleaner and ran it through the whole tank and it seems to run better now. I have been using premium all the time now.Does anyone have an idea of the best fuel injector cleaner to use. The engine has about 50,000 on the plugs and I guess replacing the plugs would be a good idea just to make sure.
Old Jun 6, 2021 | 08:37 AM
  #33
Moved to C5 Tech.
Old Jun 10, 2021 | 06:04 AM
  #34
Joevette99's Avatar
Joevette99
Default CAn I Get an Amen
Originally Posted by westy r
the only conversion kit i've seen for the c5 is $900, plus the effort of installing it ... So if e85 were $1.00 cheaper per gallon than 93-octane (and the price difference is less in many markets), you'd have to burn 900 gallons of e85 to just-barely break even (and that assumes you installed it yourself). That's 22,500 miles of driving -- and i'll bet there are plenty of people on this forum who won't put 22,500 miles on their garage-queens in ten years or more.
I'm "politically opposed" to e85 made of federally-subsidized corn-squeezin's. Consider this -- every gallon of federally-subsidized car-fuel alcohol is one gallon less of high fructose corn syrup for your sweet tea and high-calorie sodas. It also takes a gallon of moonshine out of the "liquid entertainment" market at your local alcoholic beverage control store. (okay, i'm sarcastic, but making ethanol fuel from corn is woefully inefficient; it's "34 percent efficient," which means it takes three gallons' worth of energy to produce one gallon of corn-ethanol fuel.)
that said, i'd better look at the political side of the problem, especially since everything in these hyper-partisan times seems to "circle back" to politics! E85 is cheap because it's heavily subsidized, and i suppose it's blessed as "carbon neutral." fossil fuel is scorned as "the spawn of the devil," and the wokerati are religiously-bound to curse the petroleum industry, even as they rely on it to fuel their transport to the next protest, the next riot.
My rationale for buying my corvette was partially based on the notion that i'd better enjoy it while i can, before the powers that be tax it or regulate it out of my reach to enjoy it!
amen!!!
Old Jun 10, 2021 | 08:54 AM
  #35
CinciZ06's Avatar
CinciZ06
So after reading your posts over the years we clearly know your engine building talents, so I bet that LS7 isn’t stock 😁. Now my next statement is assuming your cars ECM is the original and not a stand alone, etc. Your cars tune has a high and a low octane spark table already loaded. Most tuners simply copy the high octane spark table to the low and call it a day, and let the knock sensors pull timing as needed. So that is likely what the tuner was referencing when get asked you about the tune. Honestly as long as the tuner didn’t decrease any sensitivity with the knock sensors you could run low octane (assuming your CR isn’t crazy) and the knock sensors would pull timing where needed. And if you would drive it easy as mentioned above you likely wouldn’t see any knock to begin with. One of the benefits of getting an HPTuners setup for your car is the scanner - you can watch all of that data stream real time and see exactly what is happening.
A lot of assumptions in my statement I know. Sorry for that. I’m spending a lot of time learning Gen 3 tuning and have really enjoyed the process.
Old Jun 10, 2021 | 09:53 AM
  #36
WalterSobchak's Avatar
WalterSobchak
If you can afford the toys you can afford to take care of them right. You don't move into a nice neighborhood and skip mowing the lawn because a mower costs you.
Just find Costco's.
