Square setup 275/35/18 ?
1999 C5. Previous owner went 1" up on the wheel sizes and kept the same aspect ratio, so currently running 245/45/18 fronts and 275/40/19 rears. Suspension is stock and slightly lowered, tires are old. The car understeers badly on the limit. My use case is spirited road driving in the mountains, some touring, and maybe a trackday or two. My objective is to make the limit handling much more neutral and improve handling in general. I'm not concerned with maximizing ultimate cornering grip, not chasing lap times.
I'm considering a square setup of 275/35/18 tires, Michelin Pilot Sport 4S, with 18x9.5 wheels. The Enkei NT03+M is available in this size with a 58mm offset, which should weigh 19.x lbs. (Links: Enkei and distributor.)
Would the offset be a problem? By my understanding, this would place the wheels 7mm further outwards compared to the stock offset of 65mm. Is that correct? This guy here apparently ran 55mm offset, for whatever that's worth. The more common square setup seems to be 295/35/18 where the NT03+M comes in a 64mm offset, but 295 is the width of the rears on the new GMA T50 which uses the exact same tires and has 650hp, so I don't think 295 is necessary.
Has anyone had a problem with 35/18 rears? Obviously the speedometer will be slightly off. I'm considering the older Pilot Super Sport which comes in 275/40/18 as an alternative.
Angus
Other options:
255/35/18 @ 25" tall or 255/40/18 @ 26" tall on the front and a 275/40/18, 285/40/18, or 295/35/18 rear.
I wish I went with a 275/35 for a slightly less chunky look, but these were on sale and saved me about $150 so I said to hell with it. Never felt any understeer at the limit - really happy with how the car is now actually.
Stingaroo:
- "never felt any understeer" - how much oversteer?
- How's the comfort and road noise with 40s? Would you be happy to drive all day on pothole-strewn public roads with 35s? What tires are you using?
Comparison of current rear tire to new proposed rear tire.
Stingaroo:
Oversteer - honestly, the car feels pretty neutral to me. I like it - the front goes where I point it and it seems to stay there. Unfortunately the only track event I've done with the setup since install was a wet day, so hard to judge, but on the street it's been great. I do daily the car so no issues there. I wouldn't be concerned daily driving on 275/35s either. Old setup had 285/35-19s on C6 wheels and it was fine.
275/35R18
285/30R18
I've checked with suppliers and both the Corvette-suitable wheels from Enkei are supposedly no longer in production. NT03+M 18x9.5 58mm Offset 5x120.7 72.6mm Bore and the equivalent 18x10.5 64mm offset.
The 9.5" quoted weight was 19lbs. The only other wheel I've found close to than weight is the original magnesium rears.
$982.16 for a set on TireRack right now. Possibly less from other vendors. I know Sam Strano of stranoparts.com sells them - I would personally rather shop with Sam than TR if the deal were similar.
Edit: The ARC-8 weighs only 18.2lbs and costs only $334!! Link
I confirmed with Enkei that the Corvette-suitable wheels are both discontinued. Also confirmed with Bob from House of Wheels that they do not sell the magnesium wheels.
https://www.apexraceparts.com/shop-b...tte-wheel.html
Edit: Looks like the center bore on these might be too large(?). The EC-7 is 70.3mm.
I'd suggest going with the 18x10 as it better supports the 275 tire you want to run, which in turn will put more of that tire on the ground. Here's a link to the product page: https://www.apexraceparts.com/shop-b...tte-wheel.html
JJ - Fitment Specialist | Forged Wheels | Wheels For Your Corvette
Corvette Wheel & Tire Fitment Guides | Corvette Wheel Gallery
