Coolit V2 &V3
Running the AC does turn on the fan. You can also just have the car tuned to have the fans turn on at a lower temp. With the tune, you won't have to worry about managing it. The car will do all the work for you. However, if you really want complete control, the Colit system does work well for most people. I know of one forum member who had problems with his, but everyone else I've heard from says that it works as intended.
If you go over 35mph the the fans will turn off, even with the a/c on. So in traffic if you have to move along at 36-40 the fans are off and that's not enough air flow for a C5 to draw
air from underneath to stay cool on a hot 100 degree day.
That's just what we have found during our testing on hot summer Sacramento days in traffic.
Thank you
Christian
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
What kind of issue did you have with your Coolit?
If it didn't work and you were not happy we would replace it or refund you. We have sold a few thousand of them with very few issues with them and if there
was we always stand behind our products and take care of it.
Thank you,
Christian
was we always stand behind our products and take of it.
Thank you,
Christian
Thank you,
Christian
I appreciate you clearing things up.
Thank you,
Christian
I have no plans to sell mine, because I do not wish to pass on the potential problem to another car friend. I did not ask for a refund because I had purchased it a while back (maybe 1-2 years) and I just figured out that the Cool-It was the problem after some further modifications.
I wrote a long detailed email to Sac City on March 6th explaining the issue in detail, and never got a response. See below:
Hello,
Just wanted to make you aware that my Cool it V3 does in fact interfere with my 2003 Z06's cooling system. I can't explain how, but after I removed it, my car is consistently maintaining temps that are perfect.
I am not requesting a refund, because I have had it probably close to 2 years now, but I will never put it back on my car, or sell it to anyone, because of my experience.
A little backstory. When I purchased it, I was having cooling issues due to modifications made by my supercharger installer. I had an ACI splitter which converted my C5 from a bottom breather to a front breather. The car never had cooling issues with the ACI splitter. Well, the installer cut the back of the tray off where it deflected air up to the radiator and condenser and ran an air deflector down from the intercooler to the tray area to pull air up into the intercooler.
This kept my intake air temps in check, but the car wasn't getting airflow up into the radiator and condenser. I had to put the factory center air deflector back on underneath the car, but it was practically touching the back of the intercooler, so it still wasn't getting adequate airflow.
That's when I purchased the Cool it. It kept the temps below 240, but never below 220. I basically quit driving my car, because contrary to most opinions, I just wasn't willing to take the chance on running it with temps that high. I show the car often, so I've been trailering it everywhere I went.
Over the winter months, I have replaced my ACI splitter with a new one. I had the tray extended an additional 2 inches and now it deflects proper airflow up into the radiator and condenser again. I cut the area behind the front license plate cover out and replaced the plate cover to one with the same racing type screen that is on the front of the car. I never even considered taking the Cool it off, and when I made my first trial run last week, I was so discouraged. The ambient air temp was only around 76 degrees and the car hit 220 pretty quick. It creeped up to about 225 before I got to a gas station to fill up, and I let it sit for several minutes with the hood up to cool off some. After I left and got away from town, even at highway speed (55) it was running 220-225 without the AC on. When I turned the AC on it hit 232 very quickly and I shut it off. It came back down to 225, but this is still just too high for these ambient temps. I never turned the Cool it on, because I wanted to see what the car did without it, after my work.
I came home and was so disappointed, I was sick. Then I remembered a Corvette Forum friend of mine had purchased a Cool it about the same time I did. I called him to refresh my memory, and when he installed the Cool it V2 on his 98, he said it made his car run hotter also.
At this point I had absolutely nothing to loose, so I took mine off but waited until the next day (Saturday) because of afternoon traffic. I didn't want to get out and chance it, not trusting the car to not overheat.
Well, Saturday morning I got out (expecting no difference and a quick return trip back home) but ended up driving 70 miles to Nashville Cars and Coffee on the 2 lanes, and the car did better than I ever expected. When I left home it was 57-62 degrees all the way there and it ran between 185-194 all the way without the AC on, wether moving or stopped. On the way back home it was 75-79 degrees and it maintained the exact same temps without the AC on. Getting braver, I ran the AC most of the way back and it stayed between 196-198 all the way home, even when stopped at traffic lights.
Again, I can't explain why, but the Cool it V3 did interfere with my cars cooling, somehow. I just wanted you to be aware of this, as it has happened to 2 cars that I am aware of, and happened with both type units.
Sorry this was so long, but I wanted to explain the full story and circumstances.
Hey, if it works as advertised on someone else's car, that's great. I wish it had worked on my car also, but like in your experience, that's just not the case. I have actual data to backup my results/experience with it, and I know what the results were.
People should be informed of the potential issue before considering the product. There is a possibility it can interfere with the normal cooling system operation, with either version. This is not a vendor sale thread, and like you, I am only stating my personal experience, just like those who have not encountered any problems and are satisfied with the product.
But if you want manual control, go for it.
I've bought at one time or another most of the SCC product line (save for their trans mount and this product) and have been fully satisfied with their product quality.
