2004 Z06 Front Frame Damage
Old Jul 11, 2021 | 10:41 PM
pcutch@gmail.com's Avatar
pcutch@gmail.com
4th Gear
Default 2004 Z06 Front Frame Damage
Hello,
I ran over a friggin’ tow hitch receiver on the interstate yesterday; no way to avoid in heavy traffic. Serious damage to the front cross member. Was wondering if anyone has any recommendations on how to repair it; I assume trying to find the whole structure and replacing it would be a monumental task and serious $$$. Anyone know of a reputable place in Dallas-Fort Worth that could repair it?
Thanks !!
Old Jul 11, 2021 | 11:28 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Replace the cradle, plenty of them around, not that bad of a job. That is if the frame is not damaged, can’t tell by the pic ?? Then get it aligned!!
Old Jul 11, 2021 | 11:35 PM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
I agree with pounder. All you need is a new cradle. It's a bolt in deal. Will have to support the engine.
I'll have you know that I just spent 210 dollars on one of those adjustable B&W ball mounts and you got yours for free. sarcasm intended.
Old Jul 11, 2021 | 11:51 PM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
Yeah luckily the front cradle can be replaced independently.
That is some crazy damage. At least it didn't get the oil pan and grenade the engine.
Old Jul 12, 2021 | 12:01 AM
hotfrank's Avatar
hotfrank
Front cradle you can buy one on ebay . That is what I did $175 shp . I bought engine mounts from Rockauto and had a Corvette shop install and align $650.00 . Iam 74 some things I do and don't just sayn. Good luck.
Old Jul 12, 2021 | 07:13 AM
C5MSG2004Vert's Avatar
C5MSG2004Vert
One thing I would do is call your insurance company and see if it's covered. It should be covered under your collision and maybe comprehensive.
Old Jul 12, 2021 | 10:49 AM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
As others have said, I don't actually see any frame damage. Your insurance should cover the cradle with no problems. Good luck with the repairs. I'm sorry this happened to you. You actually got pretty lucky. It easily could have been a lot worse.
Old Jul 12, 2021 | 11:29 AM
pcutch@gmail.com
4th Gear
Thanks for the reply. Is the cradle the same for base vs. Z06? Too bad you bought the ball mount already; I’d send you this one for the cost of shipping…..but it’s not in the best condition!
Old Jul 12, 2021 | 11:31 AM
Stingroo's Avatar
Stingroo
Same part for both, yep!
I'd definitely see if comprehensive coverage will help out. If not, at least it's fixable.
Old Jul 12, 2021 | 11:33 AM
pcutch@gmail.com
4th Gear
Old Jul 12, 2021 | 12:12 PM
grinder11's Avatar
grinder11
Amazing how stuff like this shows up in places like that. Wouldn't you like to find the PO, and give it, uh, BACK!!!!
Old Jul 12, 2021 | 01:02 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Yes on the C5 the Z06 and base have the same cradle. Just look for anyone you can find.
Old Jul 12, 2021 | 02:00 PM
wrmiles's Avatar
wrmiles
Striking an object on the road is probably Collision not Comprehensive. At least it was when I hit a large price of truck tire. Deductible was higher.
Old Jul 12, 2021 | 02:15 PM
Mr. Black's Avatar
Mr. Black
As the many have mentioned before me they are the same part for a Z or a base. They are pretty easy to find and usually fairly inexpensive.
PM sent on ball mount lol.
Old Jul 12, 2021 | 09:36 PM
90lxtc's Avatar
90lxtc
Good time to consider a balancer swap and maybe a cam too. Just saying….🤷🏻‍♂️
Old Jul 12, 2021 | 11:03 PM
You may be able to find a perfectly good cradle either at Vettenuts or aescorvetteparts, both forum vendors. Good luck - looks like it could have been much worse.
To 2004 Z06 Front Frame Damage
