Maintenance queation
Old Jul 27, 2021 | 09:45 AM
iamfine2's Avatar
iamfine2
Default Maintenance queation
Hello all,
Just crossed 50,000 miles on my 2004 coupe......6 speed.
I am second owner.......Stock except for cold air intake.
Going to have the radiator flushed and any debris blown out...........and have the clutch fluid flushed as well.
Any other must do maintenance I should consider? (Yes.....oil changed regularly).
Mike
Old Jul 27, 2021 | 10:17 AM
ariZona06's Avatar
ariZona06
Transmission fluid, rear diff fluid and a good thorough brake bleed.
Old Jul 27, 2021 | 11:17 AM
Check your belts/hoses/filters too if they haven’t been checked for a while.
Old Jul 27, 2021 | 11:51 AM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Great suggestions above!
Another thing I would add is to check your harmonic dampener (harmonic balance), the insure it is still tight with no wobble.
(And you will probably be amazed at what blows out when cleaning the exterior of the radiator. )
Old Jul 27, 2021 | 12:18 PM
iamfine2's Avatar
iamfine2
HB tight and quiet and no wobble
Old Jul 27, 2021 | 01:06 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
All the fluids, and new shocks.
Old Jul 27, 2021 | 03:16 PM
iamfine2's Avatar
iamfine2
Really??........ the shocks?
What did you go with?
To Maintenance queation
