C5 Oil Drain Plug
Old Aug 6, 2021 | 01:20 PM
C5times's Avatar
C5times
Cruising
Default C5 Oil Drain Plug
Hello,
Does 1999 C5 use a washer on the oil drain plug ? If so what is the part number.
Thanks,
Charles
Old Aug 6, 2021 | 02:08 PM
Smoken1's Avatar
Smoken1
gm 3536966
Old Aug 6, 2021 | 02:41 PM
grinder11's Avatar
grinder11
Originally Posted by C5times
Hello,
Thanks,
Charles
Yes. More of an O-ring, iirc. Anyway, in my humble opinion, if you're buying anything new in regards to the drain plug, I'd look into a magnetic drain plug. Can't hurt anything, and you may be surprised what it catches!!
Old Aug 6, 2021 | 06:31 PM
punz's Avatar
punz
St. Jude Donor '12-'13-'14-'15
Ordered a magnetic oil drain plug from Ecklers, it came with a plastic washer like my 88 Van had, not the o-ring style. So it sits in the tool box for now.
Old Aug 7, 2021 | 10:53 AM
grinder11's Avatar
grinder11
Mine also has the nylon washer. VERY slight drip, one every 2 weeks, maybe. But, I fixed that. Simply cleaned each side of the nylon washer at next oil change with brake cleaner. Then put a thin coat of black, oil resistant, hi temp silicone on each side of the washer. Did one side at a time until dry. After both sides dry, I used brake cleaner to clean pan and bolt surface/shoulder the washer seats on. Then I installed the the assembly. Never dripped again!!! Basically, you're turning the washer into an O-ring. Also, try to find a drain plug that uses a much stronger, rare earth magnet. Dont remember what Ecklers uses. Mine will pick up a 3/4" combo wrench, no problem. Hope this helps.... ..
Old Aug 9, 2021 | 04:48 PM
strand rider's Avatar
strand rider
I did an end run around any questions about leaks by installing a valve made to replace the drain plug. I am pleased with what I feel is a trick part in that it works well and only had to be installed without leaks once, instead of every time. Not that his was ever a big issue, but flipping a lever to drain the oil is even easier.
I bought the valve from a supporting seller, it is a dedicated tight ball valve with a spring loaded safety on the open lever, made in Japan. Appears to be a bronze casting with a stainless ball captured with red nylon, so not magnetic. if magnets are desired, they would have to be external on the oil filter.
Another phantom issue it solved for me was that I never liked screwing a harder bolt into the softer oil pan threads,
Old Aug 10, 2021 | 12:21 PM
grinder11's Avatar
grinder11
The only problem with magnets on the oil filter (filter mag?) is it won't help any at all with tiny metallic particles going thru your oil pump......
Old Aug 11, 2021 | 07:24 PM
strand rider
thanks for the insight. I had seen the oil filter magnets for sale, but had no idea about their application or worth. I had even less of an idea about the direction of oil flow that would make a magnet on the oil filter irrelevant. I am not OCD enough to put the oil through a filter , just in case of shiny stuff, when it is discharged.
Old Aug 12, 2021 | 11:12 AM
grinder11's Avatar
grinder11
I'm not saying the magnet on the filter is irrelevant. It can't hurt anything. But the oil must go thru the pump first, then pumped to the filter. So that's why it won't help the pump. Like the filtermag, the magnetic drain plug can't hurt anything either. Hope this helps.......
To C5 Oil Drain Plug
