Air Intake
Old Aug 12, 2021 | 01:11 AM
StevieB's Avatar
StevieB
Default Air Intake
I have a K&N style Air Intake filter
What is the rubber hose that attaches to
The top of the filter for?
Old Aug 12, 2021 | 04:07 AM
03 Owner's Avatar
03 Owner
Your air pump that supplies filtered air to the exhaust at start up to help get the cats up to temp quickly.
Old Aug 12, 2021 | 08:56 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
Posted in error. How did that happen.
Old Aug 13, 2021 | 08:21 PM
StevieB's Avatar
StevieB
If that’s the case, why do we install a larger intake with more surface area Like a black wing for instance?
Doesn’t the engine breathe easier with the bigger filter?
StevieB's Avatar
StevieB
mistake post
Old Aug 13, 2021 | 10:05 PM
03 Owner's Avatar
03 Owner
The air pump only runs for a short time during start up. It pulls filtered air to inject in to the exhaust to help with heating the catylitic converter. It does not reduce the air going To your intake . It can be capped and tuned out if desired. Many people remove it when installing headers, I left mine hooked up to my headers because I used a catted x pipe and they sent the headers with the air port.
I can't see how a well functioning air pump system could reduce perfomance.
Putting on a better air intake can improve performance but from what I've read its minimal unless you have other performance mods that need a better breathing filter.
Old Aug 14, 2021 | 02:10 AM
StevieB's Avatar
StevieB
it's hard to explain the way I’m able to screw things up.
I’m replying to another post on another topic I made.
I guess you can go with the standard (StevieB drunk) explanation.
I tried to fix it and wasn’t able.
Maybe I have your reply in the C8 section as well
Old Aug 14, 2021 | 02:14 AM
StevieB's Avatar
StevieB
I figured out how to fix the problem
80 psi in the 19" wheels.
Now it's getty up and go time.
To Air Intake
