Shifter
Old Aug 13, 2021 | 07:24 PM
750green's Avatar
750green
Default Shifter
Does anyone know what model Hinson shifter this is? Looking for installation instructions Name:  photo422.jpg
Size:  1.46 MBName:  photo968.jpg
Old Aug 13, 2021 | 08:00 PM
MetalMan2's Avatar
MetalMan2
Looks to me like their standard C5 shifter: https://hinsonmotorsports.com/produc...w-o-shift-ball
Also yours came with a stock lower shift box (the aluminum colored part)
It's a direct drop-in to the stock shifter. You can ease installation by unbolting the Hinson shifter from the lower shift box, and then drop that into your car (makes it so you won't need to screw with lower box installation).
To get to the shifter, the center console comes off, then the rubber isolator that goes around the bottom of the shifter, and then you'll have access.
Plenty of how-to videos for this on Youtube: https://www.google.com/search?q=c5+c...w=1920&bih=937
Old Aug 13, 2021 | 08:03 PM
750green's Avatar
750green
Thank you.
Old Aug 14, 2021 | 10:26 AM
knewblewkorvette's Avatar
knewblewkorvette
I recommend replacing the shifter bushings too
https://www.ebay.com/itm/28406579143...8AAOSwcNJfM~Ck
To Shifter
