Tips?
Old Sep 18, 2021 | 08:43 AM
colderbythelake's Avatar
colderbythelake
Default Tips?
Looking for any tips on cleaning glass. Anyone know of a good product they would recommend? I seem to always end up with streaks. Thanks!
Old Sep 18, 2021 | 09:45 AM
glbeauchamp's Avatar
glbeauchamp
This is about cleaning the inside of the windshield, but I can't see why it wouldn't work on the outside too.
Old Sep 18, 2021 | 09:53 AM
rrwirsi's Avatar
rrwirsi
I found any glass cleaner (I use Simply Green Glass Cleaner) w/o ammonia works best for me.
Old Sep 18, 2021 | 10:30 AM
ericba's Avatar
ericba
St. Jude Donor '21-'22-'23
Meguiar’s D120 Glass Cleaner and a waffle weave towel. Be sure to wash these towels with microfiber cleaner ONLY with no fabric softeners…very important.
Old Sep 18, 2021 | 10:47 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
After struggling with the same issue for years, I finally came up with a system that works. I use Stoner’s Invisible Glass cleaner and two MF towels that are different colors (gray & red).
First, less is more when it comes to the glass cleaner. I spray a light mist on the windshield & windows and then clean them with the Gray MF towel. When done, I then re-wipe the windshield and windows with the dry Red MF towel which picks up any remaining residue and removes any streaks.
Seems to work well for me.
Old Sep 18, 2021 | 11:10 AM
silverja's Avatar
silverja
Default Another Tip - No Dash Protectant
I also suggest that one does not use any protectant on the dash. Most protectants bleed chemicals and cause the windshield to get oily. The other suggestions for general cleaning are excellent.
Old Sep 18, 2021 | 12:11 PM
Fastclient's Avatar
Fastclient
I have had really good luck with these.
Amazon Amazon
Old Sep 18, 2021 | 12:12 PM
Autoeng's Avatar
Autoeng
Everyone has their fav. Mine is SprayWay and a towel to spread / clean and a towel to buff
Old Sep 18, 2021 | 02:33 PM
rob-cyn's Avatar
rob-cyn
I have always used the glass rags that southernparts sells, pretty sure they are a vendor. Those rags are amazing. add water, wring it out and clean the glass
Zero streaks or film
Old Sep 18, 2021 | 11:29 PM
I use Adam's Polishes Glass Cleaner - have found it does not leave streaks. You may want to post your question in the Car Care section where members there can give you plenty of advice.
Old Sep 19, 2021 | 12:26 AM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
I found that no matter what cleaner I use, it’s the waffle weave towels that do the trick. So I have to 2nd that statement. Use 1 for cleaning the 1 for final pass.
Old Sep 19, 2021 | 02:53 AM
GettnBetter's Avatar
GettnBetter
Super simple but don't tell your local glass cleaner.. 50% rubbing alcohol, 50% water and a few drops of dishwasher soap
You can substitute the dishwasher soap for corn syrup
Old Sep 19, 2021 | 03:19 PM
c5arlen's Avatar
c5arlen
A little Mother's Chrome polish lightly buffs the glass, removing those leftover streaks and polishes off that hard to remove road shellac from the glass surface.. Doesn't need it but, rinse with water or damp cloth if that floats your boot!... You are welcome Bunkey. 😎
Old Sep 20, 2021 | 01:25 PM
MWWarlord's Avatar
MWWarlord
Invisible glass and 2 waffle weave towels. I have a cleaning wand made by invisible glass that makes it MUCH easier to clean the inside of the glass.
Old Sep 20, 2021 | 01:32 PM
C6_Racer_X's Avatar
C6_Racer_X
Use newsprint/newspaper to clean the windows for no streaks. Personally, I prefer the foamy aerosol window cleaners, but just about any cleaner works well if you use the right stuff to wipe it off, and the right stuff is newspaper/newsprint.
Old Sep 20, 2021 | 10:26 PM
oh1c5Pewter's Avatar
oh1c5Pewter
My method: (I never use window cleaner) Wash car, then pat-dry with thick microfiber towel(both sides), followed by waffle towel. I use those windshield glass wands w/microfiber for inside. And wash your car towels w/baking soda and vinegar. Clean towels are key!!
Old Sep 21, 2021 | 12:34 AM
Always Red Dave's Avatar
Always Red Dave
Yes Microfiber Towel is the best solution.
To Tips?
Old Sep 22, 2021 | 02:17 PM
Esoteric Detail's Avatar
Esoteric Detail
Supporting Vendor
Some thoughts on the matter. Indeed, glass cleaning can be frustrating!
Old Sep 22, 2021 | 03:07 PM
The Former's Avatar
The Former
Banned Scam/Spammer
The fastest and easiest way I've found is using a solution of water in a spray bottle with one drop of Dawn in it. Spray the glass, use a sponge to scrub the glass, use a squeegee to nearly dry the glass, follow it up with a perfectly clean cotton towel around the edges. Takes less than 5 minutes and your glass is streak free.
When my daughters visit I clean their windshields without telling them. They've called on the way home asking, "What did you do!? I can see really well!" It makes a difference in the motoring experience for sure.
Old Sep 22, 2021 | 11:42 PM
pewtercoupe2002's Avatar
pewtercoupe2002
After normal cleaning...
  • Sprayway glass cleaner with a Mr Clean Magic Eraser. (Optional use a clay bar before the Mr Clean step)
  • Waffle weave cloth buff to dry
There's also a gadget I got from Walmart which has a triangle pad thingy on the end which allows you to get all the way in the corners of the inside of the windshield.
