markers
Old Sep 29, 2021 | 02:20 PM
billbarbijill's Avatar
billbarbijill
Default markers
installing side marker lights in my 01 convertible told to take outside tailight for access to rear of markers not on 01 convertible how do i remove them HELP Bill E
Old Sep 30, 2021 | 12:23 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
If you can't get to them through the tail light, the other option is to remove the rear wheel well. This is needed on the passenger side if you have the power antennae.
Old Sep 30, 2021 | 02:07 PM
billbarbijill
thanks for the reply will do bill ellis
Old Sep 30, 2021 | 02:13 PM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
Tail light is far easier.
The outer tails just have two screws that hold them in place. From the factory, they should be T10 or T15 torx, I forget. Then 10mm thead cutting nuts hold on the rear side markers.
Old Sep 30, 2021 | 02:30 PM
t1fudd's Avatar
t1fudd
St. Jude Donor '17
Tail light fastners are #15 Torx. The 10mm nuts on the side markers are the stamped sheetmetal type (read that SHARP)
Old Oct 1, 2021 | 11:35 AM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Recommendation: Before installing new side marker lights, use the 10mm thread cutter nuts on the posts of the side marker lights to cut threads, then remove the nuts prior to installation. It is much easier to make the initial cuts on the side marker light posts while the lights are outside the car than once the lights are mounted. (Actually, this applies to any post that accepts thread cutter nuts - make the initial thread cuts prior to installing).
Old Oct 2, 2021 | 01:14 AM
MWWarlord and Route99 pretty much have it covered. The power antenna on the vert does pose somewhat of a problem in getting to the side marker nuts, but worse case scenario going in through the wheel well liner is an option. Just be careful when removing the liner because using too much force, especially on plastic parts that may be original to the car, can result in a broken liner.
To markers
