Is there a ‘best’ heat reduction mat that most people like? Looking for one that does a good job in that area.
It really depends on what specific part of the car you're trying to reduce heat on. If it's under the hood, don't waste your money with exhaust coatings or wraps. I've done it all and the thing that works best is same thing that GM, Ferrari, Porsche and every other manufacturer in the world uses....a heat shield with an air gap. You can't make heat (energy) disappear...it has to go somewhere or will start to "cook" the area it is trapped in. The heat shield with air gap to what you're trying to protect allows the heat to leave the area due to air flow moving through the engine compartment.
There's heat containment, reflection, evacuation, etc, have to figure out where it's coming from, and where you want it to go or don't want it to go. What exactly are you shielding?
