Overheating Issue
Old Nov 14, 2021 | 04:29 PM
zumbahlenm's Avatar
zumbahlenm
Default Overheating Issue
Hi, I have. a question about an overheating issue I have.
During a high pressure fuel injection cleaning I had the vehicle overheat. The coolant temp was above 240 and the oil pressure at 0? Ive never seen such an issue with the gauges.
I went to diagnose the current cooling fan and found that it is working. The fan kicks on with the AC running and without the AC on it kicks on at 225 and off at 217. I have a new cooling fan to install but im not sure this is the issue now. I can see the passenger side fan spinning however I cant see the drivers side fan because the alternator and abs module is in the way.
Has anyone experienced this overheating with oil pressure gauge reading 0 and high temp ?
Old Nov 14, 2021 | 04:42 PM
knewblewkorvette's Avatar
knewblewkorvette
I'm guessing you have two unrelated problems.
First is the oil pressure sender. The are very common to fail on the C5 though most seem to peg the needle instead of going to zero. There are a ton of threads on how to replace it.
Second problem. 240 is high. At that temp both fans should be in high speed mode which I believe is factory set at 236. My first to do if I had an issue like this is clean the AC condenser and radiator. Then clean them again. They get sooo dirty over time and sometimes a large object (like a plastic bag) will be sucked up and block air flow. I also would check the lower air dams.
Old Nov 14, 2021 | 06:47 PM
GeorgieMporgie's Avatar
GeorgieMporgie
Good advice here. I'm having some overheating issues and this is the first thing I'll be doing in the spring.
Old Nov 14, 2021 | 08:20 PM
novasscnc's Avatar
novasscnc
i agree the sensors go, c5s do run hot I put a coolit fan relay in mine you can with a remote to turn your high speed fan on
Old Nov 14, 2021 | 08:57 PM
jdmvette's Avatar
jdmvette
Night Owl for life
When you replace your oil pressure sensor, be sure to get/make a remote location kit so you can change that same sensor in about 5 minutes the next time it fails.
Old Nov 14, 2021 | 09:50 PM
zumbahlenm's Avatar
zumbahlenm
Thanks for the info.
The strange thing is the fans are working at low speed and cooling. It doesn't get hot enough at idle for high speed too kick on.
it was just that one time that it got really hott. I don't know if if was anamoly or it may happen again with fan going bad ?
The vehicle had the oil presure switch changed out because it used to read 80psi all the time on oil gauge.
Im guessing that's different than the sensor ?
Old Nov 14, 2021 | 09:57 PM
zumbahlenm's Avatar
zumbahlenm
Actually it was the sensor replaced
Part# 12616646 sensor
Old Nov 15, 2021 | 11:19 AM
knewblewkorvette
Unfortunately, the sensors go bad, even the replacements. JDMVETTE has wise advice with the remote relocation kit. When my oil pressure sender went bad, I went with the relocation kit. It's not cheap (though you can source individual pieces for less) it makes changing out the sender sooooo much easier.
Amazon Amazon
Old Nov 15, 2021 | 12:01 PM
grinder11's Avatar
grinder11
1 question I have; are you still running the original thermostat? If yes, it's getting pretty old. When driving at highway speeds, you not only get increased airflow, you also get increased coolant flow, due to the water pump spinning faster. This may help a marginal 'stat work. I've been able to extend my arm and hand to feel if air is coming from whichever fan I place my hand behind (BE CAREFUL HERE!! Fans don't care if they blow air, or remove fingers!!!!). OEM fan motors are pretty durable, so I'd try to see if they both work on high AND low, THEN change the thermostat if it's old. Obviously, ✔ your air dam and check for any obstruction in front of the condensor. Hope this helps you.......
Old Nov 15, 2021 | 01:06 PM
novasscnc's Avatar
novasscnc
the high speed fan comes on at 230 plus, the coolit relay will help
Old Nov 15, 2021 | 01:21 PM
vette4fl's Avatar
vette4fl
Default Radiator Clear Wands
This kit makes it easier to reach the radiator with water or compressed air.
To Overheating Issue
