Black on the lower recessed section for the black diffuser look is common.
Look into the tiger shark rear bumper if you want to change it up.
I can't think of any solid color that would look good, even black wouldn't imo. On a pewter car, rear being a different color just makes it look like you hadn't finished painting it.
I think just keeping it all pewter would be the best look, but if you have to do something different, paint the lower part of the rear fascia black (carbon flash metallic is suggested) as shown in the pic posted by knewblewkorvette.
And instead of paint, if you might want carbon fiber look (or not be so committed to a color), a nice carbon fiber vinyl wrap will do very well. A piece big enough for the rear bumper is going to be under $40 up to $100 if you get name brand.
Can you recommend anyone that sells precut rear bumper wraps for C5s?
You don't precut for vinyl wrap, that stuff stretches like saran wrap. They are sold 5ft wide x whatever length you'll need. You stretch it over, squeegie down and pull out the wrinkles, maybe use some heat, then cut as needed. Knifeless tape will give you the clean edges you need along the outside.
