The front wheels I believe will fit properly as they have an offset of +56, but the rear wheels have an offset of +79, which is a lot different than the stock C5 wheels. You may have a problem there. Someone with more knowledge than I have about wheel fitments will hopefully chime in. An alternative is to get some reproduction C7 wheels in the right offsets to run on the car.
My new Flow One wheels are 19 x 11 with 72mm offset. They worked fine but sat in a tiny bit; I bought some 20 mm spacers and they look great now.
I installed these c7 base wheels a year ago. 18/19. Fronts are direct fit, no issues. For the rears, I had to install a 3/4" hub adapter. (some use 1", which has a little more poke) I also had to cut off about 1/4" of the oem lug studs, but only the unthreaded portion at the end of each stud. no threads were removed. These c7 wheels have a pocket on the back side that line up with the oem lug studs, so if i had gone with a 1" spacer, I wouldn't have had to cut the oem lug studs.
IMO, those are the best looking C7 wheels, on a C5. Just beautiful, Dave.
