Tire help on Custom Wheels
https://ccwheel.com/gallery/black-ch...-piece-wheels/
I was told by CCW and the member here that these wheels are:
18X10 – 275/35/18 +41 offset to get a 2 inch Lip
18X13 – 345/30/18 +38 offset to get a 4 Inch Lip
Then, I called up Forgestar and inquired about the M14 wheels and the engineer there told me that I need to have a 10.5 front wheel to get to a 2 inch lip. Also, the engineer also told me yesterday again that changing to a 19 inch wheel will not allow for a 4 inch lip - It can only be 3.5 inches. The car pictured above has a four inch lip from what was told to me from CCW. CCW barrels have changed since John sold them a few years ago.
I very knowledgeable on modifications for performance/racing. However, as you all can see, I do not have this same expertise as it relates to wheel specs. The good news is given the backorder on the barrels, I can change my order. I am trying to go with that same look/set-up that is on this car - https://ccwheel.com/gallery/black-ch...-piece-wheels/. The problem now is that the tire choices changed from when these where made. Thus, as Jon educated me previously (Thank you) I need to go with a 19 inch wheel and that is fine.
I am now wondering if I should cancel my whole order and just go with Forgeline GX3 Open Lug. I spoke with them yesterday too, and they told me they could make the following set:Front 18X10 +41 Offset – 2 inch lip
Rear – 19X12.5 +33 Offset – 4 inch lip
Thus, what do you all think?
I'd be willing to bet that the front wheels of the car that you linked to on CCWs site have a slight poke. That's easily hidden when you turn the wheel just a little like that.
The Forgeline specs you listed will be slightly past flush in the rear and poke about 1/2" up front. A little extra negative camber will make them look just fine though.
Your ride height and alignment specs will play into all of this, so when we're drilling it down to 5-10mm of wheel fitment, it can vary based on your car and whether they "fit" is even subjective.
Clint already listed 2 front wheel specs for you that will provide a nice flush fitment. I'd recommend using those as your baseline for front fitment.
