I would do 275/35 front and 335/30 rears. Should fit great.
Thank you - I was thinking of running a 295/35/18 front with the 335/30/18 rear. Would that be better than the 275 Front or will it throw off my speedometer too much?
Happy Holidays!
The front size has nothing to do with the speedo, but the 295/35 would be a little taller than the 335/30. I dont know if it would be noticeable or not. I think a 275 fits very well on a 10.5" wide wheel, but if you can find a 295/30 it would fit well and probably look better than the 295/35.
Agreed. Switching to 335/30R18 from 295/35, you lose around .2" in overall diameter (which will vary by brand). The calculator I use tells me that it'll read about 1/2 mph faster at 60, which is whatever. Nobody's gonna notice that.
Definitely need more info first. What are the wheel offsets, are you lowered at all, and are you keeping stock fenders? If you're keeping stock fenders, you're going to want to be very selective on rear tires unless you're ok with poke/rub/crack...
Thank you everyone for your help and Happy Holidays to each of you!
The wheels I am ordering are Forgestar M14.
Front: 18X10.5 +41 (2 inch Lip)
Rear: 18X12.5 +38 (4 Inch Lip)
I have Carbon Creations CF Rear Quarters (Not installed yet). I was planning on leaving the front fenders stock.
Thank you for all of your help.
The rears are perfect for the 2" CF fenders then, no problem there. If you're pushing decent power, a 345/35/18 drag radial would work well. If you just want a street tire that will do street tire things, or even an r-compound like an R888R, you're kind of stuck with a 335/30/18 as others have pointed out. The main problem with your tire options, other than a couple drag radial sizes, is the overall height/diameter. Your CF fenders have a larger opening than a stock fender does, and putting a 26" tire (335/30/18) under there will leave you with even more fender gap to fill. If you're not lowered at all, you're going to have a HUGE fender gap. And if you want to close the gap to even a reasonable level, you're going to need to lower it pretty good. Most of us with 2" rear fenders run a 27-28" tire. Street tires of that height are much easier to find with 19 or 20s.
The front specs you listed are widebody front specs (1" wider). Unless your vendor spec'd those specifically for you for brake clearance, or you like your wheel/tire to poke noticeably, I'd rethink that front fitment.
Thank you for all of your expertise. A Forgestar engineer told me that if I order a 19 inch rear wheel, then my lip will not be 4 inches - It will be 3.5 inches. I know, not a huge deal, I guess I was just trying to get as wide of a lip as I could. I was planning on lowering my car all the way on the stock bolts (No coil overs or drop spindles). So, it would be better for me to just get a 19 inch rear tire for the 2 inch widebody rear quarters from your note above given the availability of street tires (Which is what I would prefer). The good news is I can change my order as there is a back order for the outer piece of the wheel currently.
I have not seen any pictures of guys running a square set-up with OEM Z06 wheels on the front (18X11). The reason I wanted a 10.5 inch lip is that the Forgestar engineer told me in order to get a 2 inch lip, I would need a minimum of a 10.5 inch wheel. What would you suggest?
Good call, 19" rears will be much more ideal. A 325/30/19 or 345/30/19 will be perfect for those.
Ahhh I see, you specifically want a 2" lip, so they're just choosing to push the wheel out to accomplish your goal. You'll have 2" lip, but the wheel won't fit under the stock fender. If you don't want it to poke, my recommendation would be to not do a 2" lip.
Thank you again - I will call them this morning and change the rear to a 19 inch wheel. I se that I can run Nitto Invos in a 345 on the rear. For the front, how much will it poke out? For those running a set of C5 Z06 PEM Rear wheels on the front, do they stick out a lot? I have not see any pictures with how much they will stick out. I would like to keep the stock front fenders and you are correct - They need a 10.5 inch wheel for the 2 inch lip. It is all just for looks. The M14 is a two piece wheel as opposed to the CCW Classics that are three pieces. They are both owned by Weld now, and The M14s are $600-$900 cheaper than the Classics per wheel. I use the C5 Z06 as a daily driver so I need tires that last. I am not sure how many miles a Mickey Thompson S/S lasts (I know it depends on how you drive, but I just drive normal on the streets and no burn outs, etc.). so the tires last. The Mickey Thompson is a popular tire on the 18set-up - How do they do in rain?
Thank you and all of the other members who have helped in this post. Happy Holidays to everyone.
Invos used to be a popular tire, you'll be fine with those if you want to stick with a street tire. A drag radial, or any low treadwear/ r-compound tire, isn't what you want if you want something that will last more than a few to several thousand miles (and feel comfortable driving in inclement weather).
Those fronts will stick out about an inch (assuming you're not running aggressive negative camber). They would be more suitable under a C5 wide fender for factory C6/C7 wide fender. But if you're set on wanting a 2" lip, that's what you're dealing with.
I'm familiar with the 2 piece M14 and that CCW has been owned by Weld for quite a while now, but I actually didn't know Forgestar was acquired by Weld. That's disappointing.
I ran some of CCW's 2 piece hybrid wheels for a while. The front 10.5's with 295/30/19s poked about 3/4"-1", which drove me crazy and forced me to order widebody front fenders.
Big difference between an oem C5Z 18x10.5 with +58 offset and those M14 18x10.5's with +17 offset. As Jon already mentioned, that latter combo will poke alot, with oem fenders.
My suggestion would be an 18x9.5 with +50 offset or an 18x10 with +56.
I agree 18 fronts 19 rears. I have 18x9.5 front, 18x12 rear, not a lot of tire choice with the rears, 335/30/18. I think you will have more tire options with 19" rears.
