C5 with 100k miles
Harmonic balancer wobble; big job to replace.
Clutch ( $2000+)
Color of clutch fluid. If the clutch fluid is dirty, brownish, the clutch master cylinder and slave cylinder may have damage to seals.
Look for rust/ corrosion at the battery tray and beneath it where the computer is located. Battery acid has been known to leak down and damage the electronics.
I wouldnt buy anything with 150k no matter what brand. Just too many, youre always going to be replacing something.
100k isnt that much to be concerned about IF it was maintained. Not many today do preventative maintenace like replacing cruicial parts before they go bad. Usually an oil change and wax in thier mind is "babied"
You gotta drive them. THere are 100k mi cars that are roaches and others rock solid you wont know til you get behind the wheel.
One thing that works for me is getting the seller on the phone you can tell a whole lot from a voice. Does he keep his home up ? Himself? No offense to anyone here but super fat people are usually lazy to me its a red flag
The car runs, looks, and drives like new. I got every receipt since new with the car.
I would not be afraid to buy a high mileage car as long as it was well maintained and documented.
The C5 is a pretty robust platform and 100K miles is not an automatic no-go threshold.
New battery- $86
Radio **** and door screw covers- $15
LMC5- $47
Trunk struts- $25
New convertible top and passenger window adjustment (parts and labor)- $1,300
Deck lid struts- $18
New driver's seat cushion $206 (cushion $86, labor $120)
Tires; BF Goodrich G-Force Comp-2 A/S)- $735
New plugs and wires (parts and labor)- $388.63
Brakes (pads and rotors)- $184
New sun visors (driver & passenger)- $150
New radiator (parts and labor)- $500
Differential and axel seals replaced (parts and labor)- $1,049
Serpentine belt and idler pulleys- $50
Panavex driver's side mirror (stick on)- $46
Water pump and thermostat- $140
Sway bar end links (rear 2x) and T40 socket- $52
The biggest single expense was the new convertible top in my first year of ownership, the next biggest expense was dealing with the leaky rear end- that issue surfaced last year (my 3rd year of ownership). I'd not let the miles deter you- in fact my car today with +117,000 miles is actually a better car than it was 4 years ago with 97,000 miles.
You are an ***. In addition, possibly illiterate. A true indictment of character and the American education system.
I take it you're a large fellow?
A complex design with deferred or neglected maintenance can be a very deep financial hole to dig out of, it is the stuff of legends, you might have heard. and even regular high line upkeep can be an issue as the cars decline in value, just check how much car one can buy very cheaply in a used rolls Royce. You almost have to be able to afford a new copy to keep an old one on the road, pretty much.
Most used cars are sold because of problems, few people sell a perfect car. maintenance is the key, these are high line cars, and proper maintenance costs are still high line as the cars decline in value over time, , so it often gets deferred . It is not a Toyota pick up, it was designed to be clipped together as quickly as possible, with ease and cost of maintenance left as a bridge crossed when it hits the customer.
A car of those miles will need significant repairs as parts wear out. Most fan boys will point to the engine as good for the long run, but omit the other associated expenses required to keep the car roadworthy over the years. All car wear is consumption, so anything that didn't wear out previously , will need to be replaced with high milage. My alignment guy questioned if he even wanted to accept the car for work until he checked the rubber in the steering joints, knowing the age of C5's. he didn't want to waste the effort if the car couldn't hold work, he only works on cars he enjoys, having the skill set to be selective.
I am currently planning on replacing the rubber in the torque tube, which I was too ignorant to change when I did the expensive clutch work, not really thinking that 40, 000 miles , the projected life left in the connectors, would pass so quickly. The labor alone will be over $1.000 dollars. After that, I can plan on the wheel bearings wearing out. I might get lucky on the balancer, another labor intensive repair, some last the life of the car, but I never count on luck with machines. I strive for the day when all my maintenance will be preventative only, I have a list of items yet to accomplish.
All the same concerns with any used car purchases are in play, the only unusual deal is the complexity of the design, and the increased cost to run such a design. I also look carefully at the seller along with the car. My previous owner was textbook perfect, an old guy corvette enthusiast who didn't race and had the financial ability to keep the car in good professional repair, I picked the car up from his second home on spacious gated grounds, not the retirement condo by the beach where a new Miata is just easier. .
I enjoy my high mileage convertible, but wildly overestimated my desire to work on the thing, along with my desire to learn a new skill, working on a fully computer controlled car. I can barely work my phone, so my learning curve is steep and slow, but I am getting there. Fortunately, I have some how to run an obsolete car knowledge in my past, and hope to prevent reliving again the more serious mistakes.
Good luck with your purchase decision. I enjoy having a car designed solely for fun, because that is my only need for the thing, I'm fully retired, baby.
The only mechanical issue I found was a leaking oil pan gasket. Now, that is a rather involved job on a C-5 but with the proper tools it was not a big deal to fix. While I was at it I replaced the rotors and pads, just for piece of mind. I also replaced the horrible C-5 seats, which in my opinion are not comfortable at all. At the moment the car is sidelined for a complete color change and some esthetic improvements (front splitter, rear spoiler, and '67 Big Block hood scoop.) Paint will be finished in the spring when the temps are warm enough.
The point is: Don't let high mileage cars scare you away. If it has been properly maintained they'll run almost forever. And even if they have some issues, if you're not afraid to tackle them yourself they can still be a good investment. Maybe I'm not your typical C-5 owner, but I know there are several on this forum who enjoy doing their own work and are not afraid to help anyone who wants to learn.
