C 5 Battery question
Old Feb 12, 2022 | 02:36 PM
No More Harley's Avatar
No More Harley
Default C 5 Battery question
I purchased a new battery for my C 5 and later learned about the leakage concern with the electronic system located below the battery location. Could lead to expensive repairs if it leaked.
I got the battery from a corvette shop and it's AC Delco Professional 700 CCA 95 RC. It seems like a sealed unit, but was that a good choice?
Old Feb 12, 2022 | 03:30 PM
pauly1119's Avatar
pauly1119
St. Jude Donor '06-'11
I would go with a Gel battery. The AC Delco was the one that leaked. I’m sure it’s been fixed by now but that’s what I think every time I buy a new GM product and still have the same issues from 20 years ago.
Old Feb 12, 2022 | 04:19 PM
mrlmd's Avatar
mrlmd
I'm sure that issue with the battery has been fixed by now, but you can put one of those absorbent pads underneath the battery if you are worried about it.
Old Feb 12, 2022 | 04:37 PM
No More Harley
Thanks for mentioning this. I looked up gel battery and see it is more spill proof.
I would hope I could let a regular battery go for a few years and keep a watchful eye.
D
Old Feb 12, 2022 | 07:01 PM
The Former's Avatar
The Former
Banned Scam/Spammer
I would check it weekly. Pull the battery out and the tray if you can. Every saturday.
Old Feb 12, 2022 | 07:18 PM
glbeauchamp's Avatar
glbeauchamp
I tried that but the mat was too thick (even if it was only an eighth of an inch) and resulted in the battery being up too high for the lip on the bottom of the battery to fit under corresponding lip on the battery tray
Old Feb 12, 2022 | 07:22 PM
GettnBetter's Avatar
GettnBetter
I had one of the bad GM batteries. That battery was specific way back in the 1999-2000 timeframe and was supplied in my brand new 2000 Vert delivered in November of 1999. Modern batteries don't generally have the same issue. The problem batteries leaked out of the ground terminal on the battery. In my case, it corroded the ground strap that connected to the frame causing a couple years of ABS issues and a few other funky problems relating to grounding. Once I finally identified the grounding issue, a new cable and some cleaning fixed the issue forever. Your AC Delco battery is probably just fine and won't have the same battery problem
Old Feb 12, 2022 | 07:23 PM
GeorgieMporgie's Avatar
GeorgieMporgie
I'd get a gel battery. I've had two optima red tops and they have worked flawlessly (the first one lasted 12yrs and the second is running strong). I have heard the quality has gone down lately, but that hasn't been my experience. Good luck.
Old Feb 12, 2022 | 07:41 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
I’ve been using an AC Delco Professional battery exclusively and never had an issue…I think these leaky battery issues was from 20 years ago !!
Old Feb 12, 2022 | 11:28 PM
jim993's Avatar
jim993
At least put a Battery Mat under the battery:
https://www.batterymart.com/p-batter...tm_content=All
In my view, AGM (absorbed glass mat) battery is best for the C5 because of corrosion caused by leakage from lead acid batteries which have liquid acid in them. Some call AGM a gel battery.
https://www.interstatebatteries.com/...s-the-big-deal
Old Feb 13, 2022 | 07:32 AM
richg04's Avatar
richg04
I recently purchased a 2004 coupe. The corvette dealer installed an Optima red top AGM battery. They told me about the potential downside of lead acid batteries.
I purchased a Schumacher battery tender to maintain the battery while it sits in the garage. So far so good.
Old Feb 13, 2022 | 11:07 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Not Gel......................AGM, the way to go. Any brand!
Old Feb 13, 2022 | 11:39 PM
Fcar 98's Avatar
Fcar 98
The GM Delco is junk. Yes they still leak. I had a red top that went bad after 3 years. My daughter worked at a GM dealer and got a good price on the GM top of the line Delco Pro. After a few months I noticed liquid laying under the batter. Got a pad for the leaking and that did not stop a thing. After a few months later while in for inspection acid was found down along the underneath of the car. That was it. Pulled it out and got an AGM Diehard battery. Before the red top I always had an acid battery, even an original Delco and never had a problem. That new Leaking Delco was less than 24 months ago. It was worth it to me to dump the Delco before it created more of a problem. I would be very careful with that Delco. Keep a close eye on that battery.
Old Feb 14, 2022 | 07:00 AM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
You guys know that GM doesn't actually make batteries, right? It's literally just a sticker on a Johnson Controls battery. Same as an Everstart. Same as a DieHard (formerly Autocraft, but Advance Auto Parts is trying to capture the nostalgia). It's just a battery.
They also sell AGM ones with the same fancy GM sticker.
OP - take a photo of the battery you actually have and post it.
Old Feb 14, 2022 | 01:51 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
I certainly run AGM only in my Vette. I've had pretty good luck with the optima Red Top (but any AGM is fine). I can understand why you wouldn't want to replace a brand new battery though. If you decide to keep what you have, I would check it very often. What it costs you if it leaks is WAY more than the cost of a new battery.
Old Feb 15, 2022 | 08:22 AM
Toys4Life C5's Avatar
Toys4Life C5
St. Jude Donor '21
AGM AGM AGM.
C5's are especially vulnerable and maintenance free des not mean LEAK PROOF!
Due to the the placement of the computer and main wiring harness under the battery. Here is the proof.
Old Feb 15, 2022 | 08:45 AM
No More Harley
Originally Posted by Toys4Life C5
AGM AGM AGM.
I appreciate your message with the AGM battery link.
The smart thing to do is to replace it. Since I just installed this other battery, I'm struggling with it, but leaning towards doing the right thing with a replacement.
To C 5 Battery question
Old Feb 15, 2022 | 11:29 AM
Toys4Life C5
St. Jude Donor '21
I see what you mean. If it has only been a short period of time - maybe the shop would do an exchange or shop credit?
Just a thought. Good luck to you!
Old Feb 15, 2022 | 01:33 PM
jackthelad's Avatar
jackthelad
The bad leaks were on early cars. My '98's OEM battery dumped its contents while I was at a traffic light. Engine started speeding and slowing, voltmeter all over the place and a lot of relay clicking noises. Luckily the dealer was only about a mile away, so I drove it there making sure not to let the engine actually stop, otherwise it would have been tow truck time. The receptionist took one look at the lights going up and down and heard the relays clonking about and immediately said the battery had failed totally. As the car was under warranty, they dropped in a new Delco and it lasted pretty well, about 8 years, when I changed it out about for a (then) Diehard Platinum (aka Odyssey Extreme) which has been in there ever since and is still going strong 14 years later. Only problem with Odyssey is that they are expensive - around $330 these days. But if you are in for the long haul, they are the best.
Old Feb 15, 2022 | 05:29 PM
knewblewkorvette's Avatar
knewblewkorvette
When I purchased my black 99 it had in a brand new Interstate battery in it, like less than a week old. When I got home, it came out and an Optima Yellow Top went in. Sure, it cost me $ but it gives me peace of mind..
