C 5 Battery question
Old Feb 15, 2022 | 05:55 PM
No More Harley's Avatar
No More Harley
It's that peace of mind part that plays with you.
How much to spend for how much peace of mind.
Appreciate your comment
D
Old Feb 15, 2022 | 08:11 PM
novasscnc's Avatar
novasscnc
Optima, expensive excellent battery
Old Feb 15, 2022 | 08:37 PM
RonDZ06's Avatar
RonDZ06
My car's PO put a regular lead acid battery in right before I bought it. Lasted a couple years. I just looked at it every once in a while. Swapped in an AGM battery a couple days ago.
Old Feb 17, 2022 | 06:55 PM
rrichar2591's Avatar
rrichar2591
I've used Delco batteries for over 18 years on my 04 coupe. Never had an issue. I replace them about every 5 years as preventative maintenance because the C5 does not tolerate weak batteries. If it were me, I would stay with the one you have and just check it once in a while like other maintenance items. Good luck.
Old Feb 17, 2022 | 07:19 PM
No More Harley
Appreciate the comment and have been hearing more from people that agree with your idea.
Old Feb 17, 2022 | 07:23 PM
No More Harley
The money saved from not buying a new battery can go the the new harmonic balancer I just found out is needed soon.
I'm hearing near $1500 for that in the suburbs of the DC area
Old Feb 17, 2022 | 11:28 PM
rrichar2591
Sorry your going through big cash outlays at one time. My harmonic balancer was also replaced last summer at about 75,000 miles. I can't remember exact cost but but I believe it close to the 1200 to 1300 area. I could see D.C. being higher. Here is to better luck in the future.
Old Feb 18, 2022 | 12:29 AM
If you keep the new battery, put an absorbent pad under it as mentioned. I ran AGM batteries in my last two C5s, but not so sure I would ditch a brand new lead acid battery unless the shop would take it back.
Old Feb 21, 2022 | 09:52 PM
Dave68's Avatar
Dave68
This was a long time ago, but here's what I remember:
GM originally equipped C5s with lead acid batteries. Unfortunately, the factory had been torquing the clamps, excessively and caused the battery cases to crack and leak down onto vacuum hoses. Starting in 2001, GM switched over to AGM batteries which were less likely to leak if damaged. At some point, GM went back to regular lead acid batteries. The AC Delco batteries had been extensively redesigned with stronger cases and terminal supports. They carried a 50-month free-replacement warrant.
My OEM AGM battery lasted 6.5 years before needing replacement. However, I knew that replacement lead acid batteries with the beefed-up cases were no longer likely to crack and spill acid, so I went in that direction from 2007 to 2014 when I sold my C5. I never had a leakage issue.
Side note: The following recommendations were posted in this forum in August of 2006:
I'm a GM tech, i've been through all the classes and so on, what you are sopposed to do is find the reserve capacity of the battery in the car. Take the reserve capacity of the battery and divide it by 4. You should not have a draw bigger than this number. Example: if a battery has a reserve capacity of 100 minutes, the current drain should not exceed 25 mA. I don't know if you guys are remembering to remove the key from the ignition either, but that too can keep some modules awake. On some of the newer cars, what others have said of 1hr to go to sleep is possible. Many new vehicles take a minimum of 20 minutes for the BCM to shut down, a new caddilac on the other hand, will take 45+ minutes. A 2004 Corvette has a Reserve Capacity of 110 minutes, so you shouldn't have any more than 27.5mA draw. The factory battery in a 2000 has a 115 minute reserve capacity, meaning no more than 28.75mA draw. This is also a cool little chart deal that GM gives us, showing you your battery run down time.
Current Drain Days
25 mA 30.5
50 mA 16.5
75 mA 11
100 mA 8.25
250 mA 3.3
500 mA 1.65
750 mA 1
1 A 0.8
2 A 0.4
I know GM had a revised Alternator for the Corvette's, it has a different part number. Also I can find 10 seperate bulletins for 2000 corvette's if you do a search using the term "battery"
Old Feb 22, 2022 | 04:16 PM
Corvette#2's Avatar
Corvette#2
I've had a few lead/acid AC Delcos and currently using a generic Walmart battery. No issues.
Old Feb 22, 2022 | 04:49 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
If it was just onto vacuum hoses it wouldn't be a big deal. If it leaks, it goes onto your main wire harness and can destroy expensive and hard to get electronics.
Old Feb 22, 2022 | 09:47 PM
Dave68's Avatar
Dave68
Good point. I seemed to have forgotten that part of the leak issues. Fortunately, once the cases were strengthened, over-torque of the cable clamps became less deadly.
Old Feb 27, 2022 | 06:24 AM
  #33
ztheusa's Avatar
ztheusa
Veteran: National Guard
Yet
