Push start button ⚠️
Old Feb 13, 2022 | 10:56 AM
link9a's Avatar
link9a
Default Push start button ⚠️
I know the ignition key gives a lot of problem .. how about push start button ..there is some videos about it how to install what do you think about it yes or no ?
Old Feb 13, 2022 | 12:52 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Old Feb 13, 2022 | 03:35 PM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
Why ?
Old Feb 13, 2022 | 04:01 PM
jcgunn's Avatar
jcgunn
Watch the video above and I think that you will answer your own question with a "no."
Old Feb 14, 2022 | 08:19 AM
redzg's Avatar
redzg
"Everything old is new again"?
I had push button start on my 59 GMC pickup, and on my 64 Austin Mini. Of course, the GMC was on the floorboard, and you stomped it with your boot, and the Mini was between the seats...
I do not see the point on current cars, probably due to having had them in the long ago past.
Old Feb 14, 2022 | 09:52 AM
Fast one's Avatar
Fast one
A push button system can be designed with solid state relays that eliminate the burned contacts found in used C5 ignition switches and resulting problems.
Old Feb 14, 2022 | 10:22 AM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
I have a push button system that I picked up about a year ago. However, I have yet to install it. It is possible to make them with a solid state relay. The one I purchased also allows for PKE.
Old Feb 14, 2022 | 12:17 PM
smitty2919's Avatar
smitty2919
There is a proper push button and then there is a cheaper push button. Cheap way is wiring a push button off relays but you still need the key for VATS and column unlocking. Also, how do you get in the car if the FOB doesn't work? You need the key to unlock the door anyways.
Expensive way is integrating a system that unlocks column, senses a key fob via bluetooth and removes the key all together.
For the hassle of installing the full system, I'd simply find a low mile ignition key switch and replace your worn one in under 30min. I'm not usually a fan of adding complexity.
Old Feb 14, 2022 | 12:25 PM
MWWarlord's Avatar
MWWarlord
Yeah, I have the VATS bypass, and everything to do it the "expensive" way. While I have everything I need, I haven't been able to tear the dash and doors apart to actually do the install. I might eventually break down and pay to have it installed, The real problem is other things keep coming up that I want/need to do more than a push button system.
Old Feb 14, 2022 | 01:38 PM
Fast one's Avatar
Fast one
Bluetooth and VATS aren't necessary and most C'5's have the unreliable column lock disabled. It's possible for the passive factory fob to unlock the car and activate the system without taking it out of your pocket, pushing any fob buttons or using the key. The non-passive fob would require pushing the unlock button. If the fob doesn't work the key will open the door the same way it always does. The VATS system isn't foolproof; if the contacts that read the key resistor fail, the car won't start.
Old Feb 14, 2022 | 02:09 PM
link9a's Avatar
link9a
Good info guys. ....yes and no still between 🤔
Old Feb 14, 2022 | 06:38 PM
grinder11's Avatar
grinder11
I guess I am missing something, so I'll ask the question; What the heck is the big deal about push button starting? Is it that hard to turn a key?? As for reliability, I've never had an issue with either of my original 2 keys. 125,000 miles, and 22 years later. Why change?? Nothing succeeds like success. Maybe if people didn't hang a pound of garbage from their key rings, they wouldn't have any issues? Just asking......
Old Feb 14, 2022 | 09:55 PM
link9a's Avatar
link9a
i guess i am missing something, so i'll ask the question; what the heck is the big deal about push button starting? Is it that hard to turn a key?? As for reliability, i've never had an issue with either of my original 2 keys. 125,000 miles, and 22 years later. Why change?? Nothing succeeds like success. Maybe if people didn't hang a pound of garbage from their key rings, they wouldn't have any issues? Just asking......
Old Feb 15, 2022 | 01:41 PM
jackthelad's Avatar
jackthelad
A so-called proper push button setup like the ones on newer cars which are typically start/stop systems, would involve adding yet another layer of electronics, designed by who knows who. Just another complication, IMO. My C5 will be 25 years old this year, and the only "key" problem I have ever had was the well known ignition lock issue, fixed years ago.
Old Feb 15, 2022 | 01:52 PM
Gordy M's Avatar
Gordy M
The advantage of a push button start is if you autocross or HPDE quite often sometimes you are all bucked in and forget to put the key in the ignition. It has happened to me several times a year and it would be helpful, especially with a 6 point harness. With a C6 it is not a problem.
Old Jan 8, 2025 | 04:30 PM
link9a's Avatar
link9a
Old Jan 14, 2025 | 08:24 AM
No new info posted - closing the thread.
To Push start button ⚠️
