Tire/wheel question?
Old Mar 28, 2022 | 09:27 PM
Fithen62's Avatar
Fithen62
Cruising
Default Tire/wheel question?
New C5 owner as of today, tire fitment question? Will this fit without issues?
Size 18x8.5
Size 19x10 Rear
Finish Satin black
bolt 5x120
offset 54 79
new coated rims
Tires front 2454018
tires rear 2753019 R
Old Mar 28, 2022 | 10:00 PM
jdmvette's Avatar
jdmvette
Night Owl for life
You'll need spacers in the rear
Old Mar 29, 2022 | 01:38 AM
USAZR1's Avatar
USAZR1
Size 18x8.5
Size 19x10 Rear
Finish Satin black
bolt 5x120
offset 54 79
new coated rims
Tires front 2454018
Rear tires are shorter than the fronts. Shorter rear sidewall height will look bad and the shorter tire diameter may cause Active Handling/Traction Control issues.
Need to bump the rear tire sizing to a 275/35/19, at least.
As JD already mentioned, your rear wheels have too much offset for a C5. Go with a 3/4" or 1" spacer (my choice) for correct fit.
Old Mar 30, 2022 | 03:02 PM
jackthelad's Avatar
jackthelad
C5 wheels are not 5x120, they are 5x4.75". Just enough difference to force the studs to bend.
Old Mar 31, 2022 | 11:16 AM
grinder11's Avatar
grinder11
IDK if spacers are required, or not. I ran 315/30/18 Michelin PS2s in back for years without spacers, on a 10.5 wide wheel. Maybe the 19" changes things??
Old Mar 31, 2022 | 05:36 PM
jdmvette's Avatar
jdmvette
Night Owl for life
^ moreso the +79mm is the issue
To Tire/wheel question?
